Question about Samsung SyncMaster 2333HD 23 in. LCD TV
Can only scan channels on analogue tv?
I have a Samsung LE27S73Bd TV. Now when i go into the menu there is the section to scan for new channels. However if i go onto TV i can scan for channels but if i go onto DTV that section of the menu isn't accessible so i can not get into it to rescan for channels. I had just recently rescanned for channels to tune in my N64 but it has wiped my DTV channels. I've had this problem sinse before i tuned in the N64 i just never realised it would wipe all my channels. Could anyone help me out with this, I have a 'One for all' airiel which worked perfectly fine on other TVs
  • marrk_1
    marrk_1 Feb 11, 2012
    Thanks a lot that got it working again, all the channels back.
5 Suggested Answers
SOURCE: dtv frozen
I had a similar problem and the way to solve this is to reset the set from the remote.  Set TV to standby and press Info, menu, mute then power.  The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter.  TV will turn off.  When switched on it goes into Plug and Play mode to reset the analogue and digital tuner.  Allow a full reset then you should be ok.
Peter
Posted on Oct 19, 2007
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Posted on Sep 30, 2009
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
DIAGRAMa - TV-LCD- Samsung LE27S73BD
hello would greatly appreciate if someone upload the list with factory adjusts menu service samsung LE27S73BD. I made mistake for not get note
My tv now not work good
my email is bratpatinson@hotmail.com
Jun 04, 2012 | Televison & Video
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
May 28, 2011 | Televison & Video
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
Can`t retune samsung le 37 r88.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Samsung le26r74bd won't retune digital channels
Sep 30, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Samsung LE32R7 will not retune since switchover
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
How do I retune my TV
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE32A457 32 in. LCD TV
Samsung SyncMaster 2333HD 23 in. LCD TV Logo
214 people viewed this question
Jerry Greenberg
Jerry Greenberg
