Question about Canon BubbleJet i70 InkJet Photo Printer
Canon i70 My i70 is having printing problems. 3-6 line in each document are off. The top and the bottom of the letters don't line-up. Is there some sort of default setting to align the print head. I've gone through all the maintance steps and I've printed test page after test page and all looks good until I go to print a text. We're not even going to discuss printing an image. I've had this printer for 3 years and love it...it's a little work horse. Any idea's
    Master:
  • Canon Master
  • 641 Answers
Hi. Probably your printer need a general cleaning
Posted on Jun 08, 2017
MUKHTAR
  • 2022 Answers
SOURCE: Canon S520 Bubble Jet Printer printing images in shades of green or yellow.
pls replace the colour catridge. bye
Posted on Sep 24, 2007
  • 214 Answers
SOURCE: Print Head Alignment test produces only a blank page.
Yes head probably clogged. You can try cleaning head multiple times, I think this is a pigment ink machine, so get only these carts for it
Posted on Apr 25, 2009
old marine
  • 2144 Answers
SOURCE: Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Posted on Jun 17, 2009
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
komguy
  • 2306 Answers
SOURCE: aligning print head doesn't fix the printing
You only need to clean the encoder strip. The plastic strip behind the carriage assembly. Wipe it gently with a damp Q-tip and the double lines will go away.
Posted on Jul 20, 2009
I70 Canon photo printer will not print after changing print cartridge.
Check the black cartridge and make sure the orange or yellow tape at the rear end is not still attached. If it covers the small hole on the top of the cartridge, the printer won't print black text.
Mar 09, 2012 | Canon BubbleJet i70 InkJet Photo Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Unable to print document
Please tell me you are using factory new Canon cartridges.
Third party or even worse, refilled cartridges are the preemminent cause of ink failures.
Don
Feb 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
The last line of my document only prints to top
Adjust the bottom margin to be smaller in your page setup.
Jan 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a canon i70, have installed new ink resevoirs, both color and black. It performs well for the test but when I go to print a document it simply runs two pages without printing anything. The printing...
Ok, that must be a bad communication board in the printer. It sounds bad, but it is best you get a new one unless you know someone who may fix it/swap it for u. Good luck.
Jan 03, 2010 | Canon BubbleJet i70 InkJet Photo Printer
When printing word documents it spaces the text down about two inches from the top, cutting it off at the bottom. It seems to only do this when the text is double spaced. I tried to reopen and print again,...
Have you used page setup in words? is it a problem of A4 or Letter page size? If you have A4 as default in Word and Letter as default in the printer it would react that way (letter is wider while A4 is longer...)
Jul 28, 2009 | Canon Pixma MP480 All-In-One InkJet...
Paper comes out dirty
I has been sorted it! I just print empty documents so it get better. I am having a look now  to know if the problem comes back!. However thanks very much because the forum is very helpful.
Nov 06, 2008 | Canon BubbleJet i70 InkJet Photo Printer
Occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
May 05, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Canon printer double printing and nor lining up top and bottom of letters
I had a similar problem with my 8500. I downloaded the latest driver from Canon, and the problem seems to be fixed.
Feb 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon BubbleJet i70 InkJet Photo Printer Logo
67 people viewed this question
old marine
old marine
