Question about Panasonic Office Equipment & Supplies
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
My Panasonic PT-AE4000 is giving me fits. The original 'REPLACE LAMP' warning came on around 2000 hours. I purchased a brand new lamp (ET-LAE4000, same as what came out of the unit) and had it shipped to me. While waiting for the lamp we crossed the 2000 hour threshold on the projector and it began to turn itself off automatically after 10 minutes. When I received the new lamp (no issues, it works fine), I replaced the old one per the user's manual/instructions that came with the replacement. Unfortunately I cannot get the lamp timer to reset and the projector continues to power itself down after 10 minutes. I have contacted Panasonic but their technical support consists of looking up the manual for the projector and reading me the section on how to replace/reset the lamp. The current lamp has around 2034 hours on it (you can see how long I have been working on this issue). Panasonic now wants me to uninstall it, pack it up and ship it to their Kansas facility for service ($130 to diagnose, plus the cost of whatever the fix is plus shipping both ways). I am, of course, out of warranty. I thought I would ask here before shipping it off to Panasonic or throwing it in the river and buying something new. Has anyone else dealt with this?
    New Friend:
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Posted on Jul 15, 2013
    New Friend:
I just replaced the lamp module after we ran the projector until the old lamp quit working. Since replacing the lamp I haven't been able to get a picture, menu, and kind of projection or light from the projector. I can't navigate the menu when I can't see it. It's a Panasonic PT-AE4000. I'd love it if someone could give me the key sequence so I can try to reset the lamp timer before buying a new module or paying for diagnosis/repair.
Thanks,
Katie
Posted on Mar 09, 2016
I had the same problem. Two resets of my AR-100U and I was still getting the lamp warning. Finally I disconnected the video signal from its input, turned the projector on, and was able to reset the lamp timer to zero.
Posted on Aug 24, 2012
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: Reset Lamp Hours Timer
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "VOLUM -" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
This works for Toshiba TDP T-9
Posted on Jul 11, 2008
rscheutz
  • 54 Answers
SOURCE: Can I reset my lamp timer without replacing the lamp?
That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
Posted on Mar 25, 2009
SOURCE: How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Posted on Apr 12, 2009
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
How to reset lamp hour of panasonic pt d6000se lamp
the lamp hour timer on the lamp housing, you can replace a new timer,
Apr 19, 2014 | Panasonic ET-LAM1 Projector Lamp for...
Reset timer panasonic d6000
Hello!
Have you bought bare lamp? Probably, yes. And not from "Panasonic"? yes. The timer's reset procedure is different for every model of Panasonic, including TVs. when you buy lamp with housing from Panasonic, they will give you the directions, how to. If it's "aftermarket", nope!
http://www.manualowl.com/m/Panasonic/PT-D5600U/Manual/52045
that's where you will find the procedure. it's quite complicated, page 45.
follow the directions.
good luck,
Alex.
Dec 27, 2011 | Panasonic PT-D5600U DLP Projector
How do you reset the lamp timer in a PT-DW5100?
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
Aug 03, 2011 | Panasonic PT-DW5100U Projector
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
Resetting the lamp timer for my Panasonic
You need the original remote to reset the lamp. Try to find a neighbor with a similar tv or buy one off ebay.
Mar 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
PT-61DLX75 replace lamp light reset
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Sep 20, 2009 | Panasonic PT-61DLX75 61" HDTV
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
3,323 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
