Question about LaCie d2 Network 2 NAS server (301505) Network Storage Server
LaCie d2 Network 2 Not Powering up - no blue light either
Model: LaCie d2 Network 2 Drive will not power up, not even the front blue light will turn on. I tried 2 other working AC adapters from other LaCie d2 Network 2's that we use and still - no blue lights or drives spinning up. Any ideas? Thank you.
2 Suggested Answers
SOURCE: Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Posted on Oct 24, 2009
I have problems configuring my new d2 Network 2 1.5 TB HD. Either using the LaCie Network Assistant or directly the IP address, I get a blank page with the message: Please wait while loading... and it...
Hello, I had similar problem with 2Big Network2 which was freezing the same way. I know the question is old but maybe someone will find this answer useful.
I solved the problem by updating the firmware. It may seem trivial but it took some time to figure out how to do it right.
My firmware was 1.3.7 and I was unable to easily get SSH access.
To upgrade the disk you have to
1. get it recognizable by Lacie Network Assistant. If you have a fixed IP it may not see the disk. To switch your device to DHCP assigned IP you have to reset it to factory settings (without losing data). Procedure from LaCie site works (http://manuals.lacie.com/en/manuals/d2-2big-5big-network2/reset)
  1. Make sure the product is turned OFF.
  2. Press and hold down the front button. Without releasing the front button, turn the product on by pressing the power switch on the rear of the product.
  3. Keep the front button pressed until the front LED becomes solid red, then release it. (The LED should become solid red about 10 seconds after you turn on the product.)
  4. The front LED will blink blue. When it becomes static blue, press the front button once within 5 seconds to confirm reset.
  5. If any of the steps are omitted, the product will boot normally without resetting.
2. you need the LaCie Network Assistant which you can download from here http://www.lacie.com/support/drivers/driver.htm?id=10138
I used 1.5.15 version for windows
3. Once you have the LNA installed it should recognize the disk. However if it doesn't start and says you are missing bonjour service just go to the installation directory and install bonjour.msi
4. At this point you should be able to start LNA which finds your drive. Now you need firmware (capsule file). You can't just load the newest firmware out there. Given fw version can be applied only to certain previous revisions. To check which version you need you have to check your current release. To get your current release open LNA and go to Configuration tab. The current system version is displayed in the bottom-left corner.
I updated mine to next release (from 1.3.7 to 2.0.5).
5. Now you should now to which release you should update. The question is where to get the firmware from if the LaCie support page (http://www.lacie.com/fi/support/drivers/driver.htm?id=10201) does not contain the one you need ? You can use and ftp service (it's not obvious).
Go to ftp://2bignetwork2-update.lacie.com/ (just put this address in files explorer address field) and login with 2bignetwork2 user and 2bignetwork2 password. Then browse for firmware.
6. now assuming you have successfully downloaded the firmware open LNA go to configuration tab and click "Update your NAS.." button. Authenticate with admin user and admin password then browse for the capsule file and begin updating
7. drive will need couple minutes to finish (blinking blue-red) then it will restart and when the light turns solid blue you should be able to get access to the web administration interface.
As other suggested - if you don't want to risk losing data get disk(s) (if in RAID0) and use some linux box or VM to backup data.
Jul 22, 2011 | LaCie d2 Network 2 NAS server (301505)...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Sep 01, 2008 | LaCie (300770) 250 GB Hard Drive
Lacie d2 HD Quadra 250gb
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Hope this helps.
Dec 01, 2007 | LaCie (300770) 250 GB Hard Drive
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
LaCie d2 Network 2 NAS server (301505) Network Storage Server Logo
190 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
