Question about Asrock P4I45GV R5 Motherboard
Only the cpu fan turns on pl help
When ever I turn on the cpu only the fan starts to work and nothing comes on the monitor, cannot afford a new one at this time pl help me.
Check your RAM memory. Very often bad memory will cause the video to stop working. If you have more than one stick of memory try removing one of them or all but one if you have more than two. Be sure to power off your computer first and then remove the power cord from the power supply. There is usually still some power going to the motherboard even though it has been turned off. This will protect against damaging your memory while taking it out or putting it back in. Power on your machine and see if there is any change. If not, go through the steps above again and swap the first stick of memory with one of the ones you removed earlier. If there is still not any change then at least you know that it is not the memory causing the problem. (You must have at least one stick of memory in the computer for it to boot.) The next thing you might try is to swap out your video card with one that you know is working. If that does not help I would move next to the power supply. If you have a lot of devices installed in your computer (multiple CD/DVD drives, multiple hard drives, several USB powered devices, high-end video card(s), etc) you may be reaching the limits of your power supply capacity or your power supply may be going bad. It is possible for a machine to power on but not have enough power to run all of your devices.
Posted on Oct 24, 2008
Problem upgrading CPU
Try to update the BIOS with the old CPU in, if not the new CPU could be faulty, yes I know it's new but it is entirely possible
Apr 19, 2014 | eMachines W3619 PC Desktop
HP Compaq Presario SR1738NX will turn on, but nothing besides the fans seem to work
Unless you are familiar with removing and installing the internal components of the computer it is unlikely that you will be able to fix this computer yourself. It sounds like there is a hardware fault. It could be as simple as something overheating or even a fan cable coming loose but at almost 10 years old it's amazing the system is still going. I'm sorry I don't have a simple answer to give you to make your computer just work again.
Good luck.
Feb 02, 2014 | HP Compaq Presario SR1738nx-b Desktop...
Monitor Turns Black
Hi
you have cold solder to PCB and you have to resolder the Cold solder to PCB
Thanks!
Jul 03, 2009 | Computers & Internet
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
Monitor will not turn on after booting computer
if you have onboard video try a video card that fits in PCI or AGP slot or try a different video card in place of the one you use
with everything else seeming to be correct this seems like the only thing you have not done
Aug 03, 2008 | Intel Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
CPU repair
sounds like your power supply shut down. replace the power supply with a higher wattage rated unit.
Dec 12, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Asrock P4I45GV R5 Motherboard Logo
814 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
