Question about Toshiba 42HP84 42 in. Plasma HDTV
Vertical Flashing Lines on Toshiba 42HP84 Plasma 42"
I acquired a Toshiba 42HP84 plasma TV in need of repair. When powering on the TV it produces a row of flashing vertical lines (red / orange / yellow in color against a redish/orange background). A white jagged horzontal line in the middle of the screen also is displayed with the vertical lines. This appears (on/off) at approximately 1 second intervals -- non-stop.
I took the TV to an authorized Toshiba repair shop -- obtained an estimate but declined the service based on the repair cost they quoted. I did ask if they would give me the part number or description of the component needed to fix the TV and he reluctantly gave me the following information: The problem is with the "PCB" ("Power Control Board") -- it has a "BAD POWER LOB+". I obtained a service manual for the unit and found no reference to either of these descriptions.
Can anyone help with this problem?
Thanks
  • 128 Answers
Troubleshooting PCB's of certain electronic units require advanced technical skills. no service manual of any source would provide specific solutions. the best you can get are schematic diagrams. if your field of expertise is not related to electronics, i suggest you let the technicians handle the problem for you. every shop have their repair cost qoutations. just be sure to ask for warranty of their repair. goodluck!
Posted on Oct 24, 2008
  • Toshiba Master
  • 13,433 Answers
This is most likely the whole power board, I would replace it fully or replace faulty component(s)
  • Ekse Oct 24, 2008
    you need to locate the power control board, if your not experienced in electronics its best that you replace the whole board, easyest that way. Find the board, where the power goes in, confirm that it is the board the tech ment, find the part number details on it and find a replacement with the details.
  • Ekse Oct 24, 2008
    I can look for a replacement if you post the details or you can look for it yourself, i've seen tv components (hard to find components) sold in ebay www.ebay.com do a search there.
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Intermittant vertical black bars on 42HP84
there is a good chance that I can solve your problem, although for me and others this problem usually shows itself as black bars that go from top to bottom, not just half way.  go to the following link and read the entire thread, it is very good info.  I have done this and it worked perfectly on a gateway plasma, but it also works on numerous others.  there is a guy on ebay that sells a fix for $80, and it appears to be exactly what i did.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Apr 03, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Toshiba 42wp46p
just repaired one of these with the same fault. at the bottom of the plasma panel you will see a row of ribbon connectors, on the back of the ribbon connectors are some surface mount components. resolder these components on the offending connector, clean the contacts on the ribbon connector and reconnect. unfortunately getting to the connectors is quite a job, so give yourself plenty of time. if this doesn't cure the fault then the poor connection is on the plasma panel which you cannot repair, the only option then would be to replace the panel.
Oct 30, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
42hp84
I gather there is no picture in that portion at all? If it is totally black then you have a addressing issue to the plasma panel itself. Can you post a picture of the issue?
Apr 17, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Toshiba 42HP84 42 in. Plasma HDTV Logo
432 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
