Question about Moen Plumbing
Moen caldwell shower faucet handle loose - Moen Plumbing
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 35 Answers
SOURCE: My MOEN shower faucet will not shut off the shower.
You should take the handle off. To do this, Turn Off the water supply to the Shower. Remove the handle with a screw driver or alan wrench. Now you can see the assembly. There should be a nut or some kind of threaded ring holding in the GUTS of the Faucet. Gently pull out the unit (Remember or write down how it goes together). Now visually inspect it and see if you can find an obstruction or broken piece that is causing it to stay open. If there are broken parts you can get them at a Plumbing Supply Store. If every thing seems fine and it seems to work when you have it out, then put it carefully back together, turn on the water and try it again. This has worked for me a few times in the past, Just taking it out, cleaning it , and putting it back together......Good Luck......I hope this helps you with this situation....Joe
Posted on Jan 29, 2009
jj505
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Posted on Apr 06, 2009
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
lasvegasrich
  • 65 Answers
SOURCE: I want to install Moen Caldwell faucet CA84440.
part K ( a three way hose it looks like) hooks up the cold and hot water to the water spout. heres a link to look at! copy and paste in your browser window.. hope this helps ! craig
http://www.moen.com/shared/pdf/instruction_sheets/INS1970.pdf#xml=http://search.moen.com/cgi-bin/texis.exe/webinator/moensearch/xml.txt?query=CA84440&pr=WMC_Other&hpp=10&order=r&cq=&id=4a89f5ab7
Posted on Aug 29, 2009
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
The handle is loose and the screw seems to be as tight as possible. It is a Moen single handle tub set.
might be that the spacer is missing. there is a small brass spacer located between the handle and the stem. if this is missing, your handle will feel like it's loose.
Jul 24, 2010 | Moen 3189 Legend One Handle Tub And Shower...
Delta shower faucet with a single handle lose
You need a faucet handle puller, you can get these at most home center and hardware/plumbing stores.
Once you get the handle and cover off you might just find that the control was never fully mounted.
May 26, 2010 | Moen 3175 Legend One Handle Shower Faucet...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
We have installed a new tub faucet. When the lever is pulled to allow the shower to work, the faucet sprays water.
tighten valve stem seal loose remove handle and cover the nut on shaft tighten a little at a time to much and could bind up lever
Mar 22, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
No water
the screw should be a phillips head or allen screw
May 28, 2009 | Moen 3175 Legend One Handle Shower Faucet...
My Moen Chateau model 2995 shower handle will not work, will not turn to shower postion. Handle seemed to have "frozen up".
Mar 25, 2009 | Moen 2995 Chateau Three Handle Tub and...
Plumbing Logo
159 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
