Question about Microwave Ovens
GE JES1384SF Stainless Countertop Browner Microwave how do u change bulb
MATRIX_MMX
  • 209 Answers
SOURCE: GE MICROWAVE
Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
Posted on Apr 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JES1344SK01 countertop microwave, no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall, in which case you can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams by entering your full model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
Posted on Dec 17, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
davidpsr
  • 222 Answers
SOURCE: GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Posted on Oct 10, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
Posted on Nov 29, 2009
How do i replace the light bulb on JES1651GE Microwave
http://www.wikihow.com/Replace-a-Microwave-Lightbulb
Apr 30, 2014 | GE 1.6 cu ft 1150-Watt Countertop...
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
    Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
    Jan 08, 2011 | GE JES1384SF Microwave Oven
    How do we change the bulb on this model?
    Sorry to read about your problem, I hope this helps you out.
    this model has 2 different ways depending from which factory it was built at...
    if is has plastic cover..it will just snap out... or it may have metal cover with screw on it, on the outside of the unit..
    I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
    Dec 23, 2010 | GE JES1384SF Microwave Oven
    Microwave Ovens Logo
    118 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
