Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Washer Model No. 110.27086603 wont spin unless you lift up on drum. Is that a suspension problem?
the dr
  • 447 Answers
SOURCE: kenmore washer drains but won't spin.
Sounds like the motor coupling has broken, fairly inexpensive part but does require some finesse to install. let me know if you decide to attempt it.
Posted on Oct 15, 2007
SOURCE: Kenmore Oasis HE won't drain
I had the exact same problem last night.
Here is what I did and it fixed it with NO PARTS or SERVICE CALL.
First, I took the drain hose and Blew through it with my mouth... I got air bubbles to come up in the wash bason, this told me the drain pump and hoses were not "Clogged"..
Next I took a shop vac and a 5 gallon bucket and used the vac to **** on the drain hose to start a siphon into the bucket...worked like a champ... I had it drained in less than 3 mins....
I Took the back cover off and then the drain pump off and took the 4-5 screws out of the mounting bracket and took the pump cover off.
What i found when I did this was that there was a VERY SMALL FLAT ROCK stuck between the impellor and the pump casing.
WIth a small screw driver I flicked out the rock and the impellor was free again... HOWEVER, When you do this, the impellor will turn half way and stop... half way and stop, half way and stop...etc.........IT WILL NOT SPIN FREELY like a top. When the motor is still attached to the pump, the armiture in the motor still gives reisitance to the impellor...This I PRESUME this to be normal..
I ended up putting it ALL back together except the back cover to test it...I turned it to a wash cycle and let it run for a few mins. Then i hit stop twice to cancel that wash request. Then i started a second wash cycle and the drain pump kicked right on to drain the water left in the basin from the first test wash..... So far she's purring like a kitten..... Fingers Crossed of course...
Posted on May 18, 2008
huuum
  • 750 Answers
SOURCE: KENMORE 110 -LETS WATER IN..DOES NOT SPIN
Hello Sylvia,
You said,
HELLO...I HAVE A KENMORE 110 WASHER, LETS WATER IN BUT DOES NOT SPIN. PLEASE HELP. SYLVIA
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts.
If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed.
As the clutch wears out, it may prevent the unit from spinning well or at all.
If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and draining, the other.
It's possible for a motor to burn out in one direction and continue to operate in the other.
If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool®
have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective,
the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When this is the problem,
you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety,
washing machines are made so that they spin only with the lid closed.
The lid switch prevents the spinning action when the lid is up."
Bless You,
Please give me a good rating for the sound advice , before you sign off.
Thank You
Posted on Sep 17, 2008
philbran
  • 242 Answers
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Posted on Dec 30, 2008
tbirdfan1
  • 3051 Answers
SOURCE: My Kenmore Elite HE 3 model #110 4822 201 will not
Hello there:
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool and Kenmore have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Posted on Jan 15, 2011
Kenmore Elite oasis 2709 ol signal came up, initially sears repairman said that the drum needed to be replaced so they ordered one and about a week later it showed up, then I wait a week for service guy to...
The "liquid" you here sloshing around in there is supposed to be there,it helps it to stay balanced when it spins at Hightower speed. Also you should use the "clean washer" cycle about once a month,... It helps get rid of the hard water deposits that build up, unless you have a water softener unstaaled in the house - but most people don't. If you do a lot of laundry, the strut rods that hold the drum in place wear out( mine lasted six years) and that will make it out of balance when it goes into drain and spin cycle.
Oct 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Our Kenmnore Oasis Model 110.2703 washer gets out of balance with all size loads and stops due to excessive vibration. The washer was checked with a level as required by the manual and is level. The...
Raise the lid by depressing the clips that are about 2" in from each side. See the white plastic "balls" that lie in sockets on top of the suspension rods? Lift them up and clean the socket and ball on each corner, apply new grease and you should be in good shape. Two people make this a whole lot easier.
Jan 13, 2011 | Kenmore Oasis 27042 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The washer says f1 and wont rinse clothes so how can i reset it
washer fills but will not drain or spin!! should agitator spin seperatly from drum??? mine will not move!!
Jun 07, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Washer wont spin
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
UL ( unbalanced load ) signal appears, washer will not spin
Re-balance the load, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis washer
top loaders use the same motor for wash pump and spin to spin the clothes the motor direction is reversed and a solenoid releases the drum brake allowing the drum to rotate this is governed by a set of clutch shoes in the pulley if these are worn then the machine wont spin at full speed but ol on the display indicates overload so check the solenoid is releasing the drum usually heard as a loud clunk on spin start
Apr 01, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
173 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
