Question about Drills
I have a Guardian floor model fdm16sp drill that needs a rack. Any idea where I can get one
3 Suggested Answers
  • 760 Answers
SOURCE: I have a Guardian Power floor model drill press.
Can you move the spindle up and down with the handle? If you can't make sure the spindle lock is not on. Is the spindle clean and rust free , well lubed? Here is a link to a manual for your drill press: http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=15-331 You can order parts here. Usually the return spring can be adjusted with a nut on the left side of press. Possilby the return spring could be broken.
Posted on Jul 12, 2010
rowdy45176
  • 2176 Answers
SOURCE: I need to replace the
I looked at a schematic and owners manual for a 17-950, COULDN'T find the one you listed and if I am not mistaken I believe there is a collar holding the rack in position and if you snug the table or somehow keep from falling you can loosen the collar and using the height adjustment move the rack so you can remove it. BUT I also found a dedicated help line that I would suggest calling first about this and the number is 1-800-223-7278.
Posted on Feb 25, 2011
I have Guardian Power BDM58-5SP drill press that needs a table. Any idea where I can find one 11-22 round one with a 44mm post?
ry the manufacturer spares department
try reputable tool supply shops
try e-bay
try your local dump charity shop as there are many units disposed off that have tables attached
Oct 11, 2016 | Drills
Where can I get a rack retaining ring for a 12" master force drill press
you may not be able to master force looks like they are discontinued
cant find any parts supplier for them
may need an engineering shop to make one for you
Apr 30, 2016 | MasterForce 12" Drill Press
I need the owners manual for Guardian Power drill press Model# FDM-58-16S
Hello, Call Guardian at 1-877-934-3585. For help with obtaining a manual.
May 15, 2014 | Drills
I have a guardian power floor model drill press model FDM 58 12SP where can I find a 5/8 chuck
in perth i would try ron mac machinery sales.. in other states also machinery sales for trades or companies in steel work.. pete
May 11, 2014 | Drills
I have an old Guardian Power drill press and I broke the handle. Does anyone know where I can find parts for it? Model #BDM58-5S
Jet JDP 12 Parts List and Diagram 707300 eReplacementParts com
This site has parts for several brands of drill presses, so you may be able to match up the part that you need. The page I tagged is for reference . You'll have to search the site for a part that possibly works for you. Hope this helpful. There are other sites that have parts, but I did not find the Guardian.
Dec 01, 2013 | Drills
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
I have a Guardian Power floor model drill press. The spindle will not retract. I would appreciate knowing how to fix this and where I can get parts. Thank you. Bill Powell
Jul 12, 2010 | Delta 15 331 15" 115/230V Variable Speed...
I need the owners manual for a Guardian Power drill press Model# FDM-58-16S........Help...................
I'm looking for a Owner's Manual for a 16 speed, 1/2 hp, Heavy duty Guardian Power drill press.
Apr 17, 2010 | Drills
Broken elevating rack
Please contact your manufacturer for parts. FixYa.com dispenses advice ... not sell parts.
Thanks for your question
Jan 20, 2010 | Shop Fox W1670 1/2 HP Floor Radial Drill...
Drills Logo
182 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
