AIWA AD-F810 reel torque
Hello, I just replaced both belts on my deck, which was been standing unused for almost 10 years. But now when flywheel is OK, another problem raised. Reel cap-s don´t turn, which means that tape will not wind/rewind and playback is cancelled after 2 sec, because tape will not be winded on poles. The reel motor is turning and also the pulley and rolls are turning as they should. But it seems to me, that reel tape assembly turns too tight (when turning by hand). So maybe the resistance is too high for the gear assembly to be able to turn cassettes. I took all the cassette drive assembly out of the deck, but it is still impossible to see if there is a way to make reel tape assembly to turn easier. If I remember correctly, they should turn without any resistance, if the brake pad is lifted of from reel flywheel. Any experience and comments how to fix this problem? Thanks, Avo.
    Problem Solver:
  • 8 Answers
If you have a service manual, go to exploded view 3 and look at 31.
This is the FR idler sub assembly. Check the rubber tyre or tire, see if it has hardened. This is driven by the reel motor and flip-flops between the table reel assemblies to drive fast forward,reverse, and play take up.
Also check the reel assemblies for oil that's gone to gunge.
I'm using brass valve oil with PTFE by Denis Wick, That's musical !
Posted on Mar 27, 2013
  • periphix40
    periphix40 Mar 27, 2013
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Posted on Jun 20, 2008
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
  • 319 Answers
SOURCE: threading reel to reel
Depending on which brand of recorder you have, most do have a general threading scheme. As you are facing the unit, the supply (full) reel would be on the your left and the take-up (empty) would be to the right. Position the supply reel so that the leader end of the tape will be on the outside. Pull the tape end around the shut off sensor lever so that it moves freely. Now pull the tape leader between the rubber pinch roller and capstan (in the case the unit has dual capstans). If it has a single roller on the right side, pull the tape between the heads and then between the roller/capstan. If unit has dual shut off sensor levers, pull tape around this sensor as you did the first, making sure it moves freely. Then thread the tape leader into the take-up reel slot. Press play. Both reels should turn counter clockwise.
Posted on Aug 03, 2008
SOURCE: Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Posted on Aug 20, 2009
Grubhead
  • 5190 Answers
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Posted on Sep 11, 2009
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Aiwa AD-F810 when a tape is place and I try to close the door it won't but it will close and open with out any tape ? the deck is mint
i had the same type deck years ago, some decks have a two part door, make sure the outer door is clipped on to the inner mechanism correctly, may just have to be popped off. then re pop back on to inner door. jim d
Apr 26, 2011 | Samson Audio Players & Recorders
Instructions to replace belts on teac cx650r stereo cassette deck
The replacement of belts on any deck requires you to dismount the transport section and take thrust plate off as well as other mechanical parts to get to the belt location. It is at this time that the reel table should be removed and rebuilt as the take-up torque due to old felt will be excessive and you don't want to have to go in again. Oiling of the Flywheel bearings is also good to do at this time.
If you can not do it I work on deck as Skywave Tape Deck Repair near Chicago. That is one option. There is another service provider in New Jersey.
Jan 22, 2011 | Teac Audio Players & Recorders
Replace capstan belts
(Unplug the unit before doing the following!)
Pull the top off (8 screws). On the back of each deck you will see a motor (silver cylinder 1.5"Diam x 1.25"Long) mounted to a removeable plate. It's kind of tricky, but... Loosen the bottom two screws securing the motor mounting plate (not the motor itself) to the rest of the deck. Then completely remove the top two screws, so the moter and plate fold away from the rest of the deck. With some care, you should be able to remove the old belt and slide the new belt over the capstan flywheel and motor pulley. Fold the motor assembly back into place and secure the screws. That should do it!
Note: I used a jeweler's screwdriver and needle-nose pliers to turn the screws on the motor mount. This is real fun with all the wires in the way, but it is possible. I Also pulled the screws on the power transformer, to move it, so I could get at one screw for deck #1.
BY THE WAY: I'm ready for new belts myself, and haven't been able to find a source, except in germany. Any ideas??????
Mar 22, 2009 | Audio Players & Recorders
Aiwa AD-F800 Cassette Door problem
95% of all tape deck mechanical issues are caused by the belts going bad. if they have not been changed, then goto turntableneedles.com and click on the "find my player" link it will take you to the two most commonly failed belts for your model. They are square belts. If you open it up and see flat belts then email them measurement information by threading a piece of string from around the pulleys where the flat belt is found. ONLY OPEN AND ATTEMPT THIS IF THE POWER UNPLUGGED & YOU ARE QUALIFIED OR EXPERIENCED WITH ELECTROMECHANICAL DEVICES.
Jan 16, 2009 | Audio Players & Recorders
Rubber drive belts wanted for Aiwa AD-F810 cassette tape recorder
my aiwa brand cassete recorder model : TP-VS485 drive belt is broken, how replaced and where I can find spare parts
Nov 02, 2008 | Audio Players & Recorders
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
Nov 24, 2007 | Audio Players & Recorders
453 people viewed this question
 Grubhead
Grubhead
