Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tuner how easy is to replace the tuner in a D52W20?
  • Michael Jackson Oct 24, 2008
    THANKS THE CABLE MAN BROKE OFF THR CABLE CONNECTOR. WHAT KIND OF SOLDER DO I NEED AND DO I NEED FLUX?
    MAYBE YOU COULD HELP ME WITH THE GREY BOX IN THE TOP RT CORNER WITH A # 2 IN IT, CANT SEEM TO GET RID OF IT
    Genius:
  • 1,030 Answers
Whats wrong with the old tuner? did the connector break? depending on the damage the connector can be replaced to replace the tuner right out i would call a medium difficult level. it invovles removeing the signal board the board with the tuner on it simply unsoldering and replacings care should be taken not damage surface mounted components. at the shop it is possible we repair these tuner which involves opening the can tuner and soldering a new connector to the can of the tuner.
Posted on Oct 24, 2008
  • Willie Howell Oct 24, 2008
    so u are going to atempt repairing the tuner instead of replacing.. good for you. have you ever done soldering. i use a standard 60/40 general purpose solder. you will still have to remove the tuner from the bord. then remove the cover of the tuner. do u still have the connector. no flsx needed or ive never used any
I HAVE A D52W20 RCA 52" REAR PROJECTION THE
Bad connections on the vertical output ic, also check connections in tuner/if module, Real common with RCA to look like vertical trouble.
Nov 06, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the tuner on a 52in RCA D52W20 located, I need schematics or an idea where it is
the tuner is on the small signal board which is the large green board on the right when looking in the rear of the set. The tuner is encased in metal shields and is attached to that board most versions have two tuners soldered side by side.
Sep 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
THE MALE ADAPTER FOR FEMALE CABLE INPUT IS BROKE, CAN I buy just that piece
You can but you have a real problem---someone is going to have to unsolder and remove the tuner that the coax fitting is a part of--not real easy on this model----
Then to replace it you have to unsolder whatever is left of the old pin from its center that is soldered into the circuit board inside the tuner-----
There is a much easier way to deal with this---if you have cable, direct TV, sat, whatever----get a box that allows you to connect into one of the sets of audio and video jacks on the back of the set---you bypass the cable fitting and the tuner--you can even use a old vcr and it does not have to be able to play--just use it as a tuner and go into one of the video inputs---
Let me know if you have concerns or questions- I am here to help.
SD TECH
Oct 31, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52in. has a blue screen... Will not show a picture?
  1. Check menu to make sure a signal is present. try video 1 with a external video source such as a VCR. If this produces a picture check for tuner signal by hooking the VCR to the antenna and tuning to channel 3 or 4. If their is no picture check antenna connector on back of set for looseness. If loose resolder antenna connector in tuner. If all these test fail the tuner may be defective and will require replacement.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I just need to replace tuner on R.C.A. model D52W15 part # 264658
you can get replacement tuners at the following link. Call or leave a email with what youre needing.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W19 tuner replacement
Tuner is a very critical component to desolder without ruining the board. You can get a replacement signal board at the following site they have a promotion going on leave them a email and you can get a new replacement board for several hundred dollars cheaper than normal. Heres the link.
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tuner replacement
You are going to replace the whole tuner module? requires a t20 torx driver.. to take back of. a small flathead screwdriver. solder iron with solder wick.
Rca d52w15 tuner replacement
yes i do believe this tuner will work even with the missing pins...i have replace these here at the shop and found the pins unused...I would go ahead and try it... i dont think there will be any problem let me know if it works
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52wi5 tv tuner replacement
i have noticed that the new tuners are missing a few pins. i believe that it will work. what is the exact make and model of the set there is a tiny printing of the model above the model # i has d52w15...yx....something. you need this to cross reference the tuner. let me know and i will cross ref it
RF Tuner
the tuner for this unit is a rca 264658 componet is nh101
Dec 10, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
