Question about Garden
Loading small round bales onto trailer lost power
It acted like it was under a strain so I checked every thing got back on and downshifted and tried giving it some gas and it died, and now it won.t start,,,, where to begin as the svc dept is closed and i need to get it started to load it on trailer to get there on monday Thnxs
txkjun
  • 409 Answers
SOURCE: Hello, I have a 2002
You will need to run a fuel pressure test on it to see if your fuel pressure is correct. How many miles are on the car and when was the last time the fuel filter was replaced.
Posted on Dec 26, 2008
SOURCE: hard starting loading up with gas in cylinders
float valve in carb is leaking fuel into engine. It ususally gets in the oil,too, when this happens. clean float valve and change the oil. Or put a shutoff valve in the fuel line and close it everytiime you park it (not a good solution but it works.)
Posted on Mar 12, 2009
ImpalerCo
  • 13 Answers
SOURCE: hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Posted on Mar 14, 2009
Healeyman
  • 1198 Answers
SOURCE: mower starts runs begins to back fire and run
Sounds like it is leaning out, running out of fuel. That can be the strainer at the gas tank, any fuel filters it has. Disconnect the fuel line from the carb and see how good the flow is to it, and check for water. A new spark plug never hurts.
Posted on Apr 29, 2009
Molson02536
  • 3854 Answers
SOURCE: Gas smell when starting and small dripage when back up from under engine
It sounds like the return fuel line is leaking. There are two fuel line and one is the high pressure line which goes to the fuel pressure regulator then to the fuel rails. There is then a return line from the fuel rail to the gas tank.
With the amount of fuel leak, it's going to be the return line since it's not that bad compared to the high pressure side. Follow the fuel lines from the drivers side around the steering shaft to the engine. The high side and low side (return) run side by side and you should see it leaking when the engine is running.
Good luck and hope this helps.
Posted on May 25, 2009
What oil pressure is needed in the rams on the back door which set bale pressure on a krone 1250 round pack
tough question that
http://www.mascus.co.uk/specs/round-balers_985594/krone/round-pack-1250_1024021
Krone Round Pack 1250 Baler, multicut 17 knives, , rotor feed, 15.0/55-17 tyres, bale kicker, 2.0m pick up, wide angle pto c/w cam clutch.
Jul 04, 2016 | Cars & Trucks
Why is has dripping/running constantly from drain line on bottom of carb?
It sounds like your float is stuck in the open position.
You might try tapping on the carb with a screwdriver handle or small hammer(just tap, don't hit).
If that doesn't get it you might shake it from side to side a bit to work the float out of the bind it is in.
You may be able to pull the bowl off of the carburator and loosen it if the first two things don't get it fixed. The bowl will have a wire bale that runs under it and keeps it securely fastened. There may be a screw that is attached to the bale that you turn to tighten it securely.
Once you expose the float, just a tap with you finger should set it free. It will be attached to the carb body on a hinge and only moves up and down.
Once you have it free, replace the bowl.
The purpose of the bowl is to hold a small anmount of fuel to give the engine some quick giddy up,
When the bowl gets to a point she it need to be filled, the float drops and opens a valve allowing fresh fuel to refill it.
Good lick with that.
Feb 11, 2016 | ATVs
Lost power to turn sig airbag light and heater control.I pluged trailer lightes in to my tow package
The trailer might have a bad ground. My camper does the same thing to my truck. Try directly connecting the trailer ground to the frame of your vehicle. This might solve the problem as it did for me.
Nov 16, 2012 | Cars & Trucks
200 1200 sporty... Traveliing down the highway at
Sounds like you lost your ignition for some reason. Now, as to what exactly happened, I have no idea. I have seen people accidently hit the "run/stop" switch while riding. You might want to check the connections on your coil, as well as the connector from the electronic pickup on the right side of the engine. Look under the bike on the right side near the frame tube. There is a wire that comes out of the right engine cover below the round "points cover". Follow the wire back until you come to a round plug. If you can, disconnect the plug and check for corrosion. Put a bit of "bulb grease" (that white stuff they put on a turn signal or brake light bulb) on the connectors inside the plug and replug it.
On the left side of your bike there is a triangluar plate, Remove the plate and you'll find the ignition "black box" under it. Check all connections and look for chaffed wires.
I hope this helps. Good Luck!
Mar 31, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Pontiac 6000 1985 2.8 v6...
try a new catylatic converter,If it only goes 55 m.p.h , or under heavy strain,thats usully what it is.
Jul 22, 2009 | 1997 Ford F250 SuperCab
2006 Dodge RAM 3500 - Left turn signal on trailer doesn't work
Well you are not ALONE .....my 06 3500 does the same thing. no left turn or brake lite on towing. would love to know the solution before taking an AXE to it!!! thank you jesse
Jun 06, 2009 | 2004 Dodge Ram 2500
Excessive fuel smoke coming from my exhaust
Change fuel filter. I know it doesn't make sense. It seems like you're getting too much fuel, so the filter shouldn't be plugged. But that's how they act.
May 19, 2009 | 1989 Ford F 250
Loading back on traiker
Float on style trailers are designed with immersions depths and vertical guides to allow the boat to be driven onto the trailer. But not at full throttle, only enough power to move the boat over the bottom rollers/guides. Some trailers are designed to have the boat winched onto the trailer. For this style, you drive to boat to a starting point and then use the winch to pull the boat the remaining distance. These sometimes have a release mechanism and hinge/pivot point to allow the back of the trailer to drop below the normal towing position to make recovery easier. As the boat is winched into position, the weight of the boat will cause the trailor to pivot and return to the towing position.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
