Question about Frigidaire FEF366 Electric Kitchen Range
My oven flased an F9 error....
What is it and how can I fix it?
    Problem Solver:
  • 12 Answers
The solution to this issue is to finish running the self cleaning feature to this oven, Shutting off the oven or opening the door before the self cleaning feature has completely run will send a F9 error from the safety co0ntrol unit feature built in to the system bios of the control circuit, You will need to close the oven and set the option self cleaning to run now. if your error message prevents you from taking these steps you will need to unplug the oven from the wall socket and let it sit for an hour to reset the screen and then run the self cleaning feature all the way trough, it will shut down on its own when the self cleaning cycle has completed
Posted on Nov 05, 2008
Oven does not work displaying a F9 on the display
F9 indicates a fault with the door lock (for self-cleaning mode). Could be the lock itself, the control board, or wiring in between.
If you can use an ohmmeter, this link has some pretty good instructions for troubleshooting a GE oven with F9 error. It does require cutting power at the breaker box and some specialized tools, plus the repairs are somewhat complicated.
How to Fix F9 on GE Oven Hunker
Oct 21, 2017 | Kitchen Ranges
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
GE profile range F9 error code
F9 indicates a problem with the wiring specifically listed as program w/ door circuitry. A qualified service tech may be the best choice to fix this problem.
Jan 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
Frigidaire FEF366 Electric Kitchen Range Logo
343 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
