Question about Kenmore 63252 Microwave Oven
I have kenmore microwave model 721.80012401 it does not heat, I checked the magnetron thermostat, capacitor and the only thing that does not check out is the diode,can the diode cause this problem?
  • 183 Answers
Yes your diode can keep it from heating but it usually makes a loud growling if diode is bad. there is also another thermal disc on the other side of the oven that could be open. usually can see it in a hole in the plastic with 2 wires. if there is continuity on both this and the mag thermal, you may have a bad magnetron
Posted on Feb 12, 2012
3 Suggested Answers
SOURCE: Microwave heats but slowly.
This is the second time I have requested assitance on this site with no response. The beginning of this thread dates back two months. Why would I ever want to pay for support when it is so poor at this level?
Posted on Mar 04, 2008
  • 1126 Answers
SOURCE: need installation instructions
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0411402.pdf
I could only find the owners manual. Hope this helps.
Posted on Sep 03, 2009
Kenmore elite microwave not heating
This a common issue and caused by one of three things, magnetron, "heats food" cracked high voltage diode, and a shorted high voltage capacitor.
Mar 23, 2012 | Kenmore Microwave Ovens
Kenmore microwave model numbr 72180039700 does not heat anything
The cause will be one of three things, the magnetron "common problem" or the high voltage capacitor and diode. If the magnetron turns out to be the problem, it will be cheaper to replace the microwave oven.
Mar 10, 2011 | Kenmore Microwave Ovens
MY MICROWAVE IS NOT GETTING HOT INSIDE EVERY THING ELSE SEEMS TO WORK FINE I REPLASED FUSE I THINK ITS THE CAPACITOR
could be the capacitor but also could be the magnetron which is a common problem with heating and one of the main sources of heating.... everything will work with a bad magnetron also it just will not heat... common problem with these... to test the capacitor you will need a meter that test microfarads or mfd good luck to you ....
Jan 04, 2011 | Kenmore 63252 Microwave Oven
Our Kenmore microwave turns on, makes noise but has no heat. Any suggestions?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 30, 2010 | Kenmore 63252 Microwave Oven
I have a Kenmore model 66561689101 that doesn't heat properly anymore. What is wrong?
The most common problems of microwave oven are the HV capacitor, HV diode and lastly the magnetron which is the main part of M O. check the capacitor and diode first, if its okay, then you have a decision to make. replace the magnetron or the whole unit. magnetron are costly
Jun 28, 2009 | Kenmore 62622 Microwave Oven
Kenmore microwave model 665.68681891 runs but won't heat
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Oct 25, 2008 | Kenmore 62622 Microwave Oven
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Jan 06, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore 63252 Microwave Oven Logo
181 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
