Question about Craftsman Garden
Craftsman 7000 mower deck will not move
7000 42in Zero turn mower
  • Joe Ackerman Feb 11, 2012
    The Mower deck height adjustment is motor controlled. I think its seized but not sure.
    It attempts to move when switch is activated. Anyone know of any seizing issues?
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 11 Answers
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Posted on Jun 24, 2009
  • 138 Answers
SOURCE: Craftsman 42in mower deck spindle breaks and Strips.
there are thousands of these mowers out there, and most people do not have the problem that you are experiencing - let's face reality, you are hitting something, that's the only way these break - it is impractical to make a machine that will mow through rocks, stumps, and water pipes and not break - also, sears does not MAKE anything, they contract companies to make products for them - if you want a thicker, tougher mandrel housing, log onto www.amcpartsstore.com. they recently began offering a heavy duty version of the mandrel housing, part no. 130794. i've seen these and they are definitely beefy - just be sure to put everything together correctly and tighten all the nuts and bolts firmly, and try to avoid the rocks and stumps
Posted on Aug 26, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
Craftsman zts 7000 deck adjustment
The front hitch rods are used to raise or lower the deck from front to back. If the adjustment isn't working, look for something that's obstructing movement.
Jul 19, 2014 | Craftsman Garden
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman zt 7000 zero turn riding mower will crank but won't start and the starter get really hot
sounds like a safety switch problem. but maybe you can help me i have the same model do you have a lot of jerking when you start off of turn with yours?
Apr 10, 2012 | Craftsman Garden
Disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
