Question about GE Washing Machines
GE WCVH6400 front loading washing machine doesn't spin
Error code is e54, I have a new inverter on hand, does someone have a repair manual to tell me where I am going to swap this out?
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
SOURCE: Washing Machine Will not Spin
Howdy!
I just finished completely disassmbling my machine for the exact same reason you mentioned. And I mean completely. Not a screw still in place. It took 4 hours.
Turns out in my case that electrolysis is the problem.
What I mean by this is that behind the inner drum is a three pronged heavy metal piece made from galvanized steel which attaches to the inner drum by 6 large screws. Coming out of the center of this is a post which comes through the plastic drum housing into the back of the machine and hooks to the assembly your belt runs on. (This wheel for the belt looks a bit like a tire wheel well but thinner.)
What the problem is for me is that the piece inside that attaches to the drum (the galvanized steel one) has completely corroded from electrolysis and broken. All three prongs have completely broken off making it impossible for the drum to turn. I am a little irritated with GE at the moment because had they used an appropriate metal, knowing it would be constantly bathed by the water from the laundry loads, I would not be in this predicament. I am a little disturbed that a 15 lb metal part has broken before the rubber belt even wore out!
I mysel am on here right now trying to find the exact name of this part and possibly a part number so I can order it and replace it. My basement is currently a compete mess from this project and I have laundry waiting to be done.
I am also looking to see if maybe this just might be a recall situation where we can get some help with getting the part due to what I feel is faulty manufacturing.
Should I come up with any of these answers I will come back on here and share them with you.
In the meantime, unless you have the appropriate tools, plenty of time and plenty of patience, I don't suggest tearing into your machine like I have. It may be worth calling a appliance repair place for you.
If you want to be certain that this is in fact the same problem with your washer, open your machine and see if you can freely move the drum around by pushing on it. If it isn't a good solid middle of the machine spin and has play in it wear you can lift the drum a bit in any direction, we have the same problem.
Just from your description, I am betting we do.
I hope this is helpful, and I'll let you know what I find out!
Posted on Jan 13, 2008
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
took off the screw clamp and it had a sock in it. works great now thanks
Posted on Nov 08, 2008
SOURCE: WCVH6800J1WW GE Washer error codes
need same solution, please post
Posted on Jul 30, 2010
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
May 12, 2017 | Washing Machines
My F1-3000N WNQ treadmill is stop and is showing E54 error, what does this error code mean?
If you wish to get some details treadmill error codes and calibration ; check the site linked here. http://electro-medical.blogspot.com/
Nov 05, 2016 | Exercise & Fitness
All of sudden wnq treadmill show e54, what to do?
If you wish to get some details about treadmill error codes and repair then check the following link
Aug 20, 2016 | Exercise & Fitness
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
What does error code e54 mean
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
Aug 09, 2014 | Electrolux Dryers
What e54 error code mean on an electrolux dryer
Could be:
  • Voltage too low.
Dado
Error code e54
TEST this steps and fix it. This error code is E54 which is something to do with the motor.What you can try first is pull machine out and take off the back panel. From there you will see the motor at the bottom. Unplug the wiring block from it and start the machine again.
Jul 23, 2013 | Zanussi Washing Machines
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
My washer doesnt spin at all on different settings.it is a kenmore super cap. 3.5 quiet tumle action washer front loading type, model nos. missing
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Sep 22, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Washing Machines Logo
96 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
