Window XP Home SP3
The display on my Windows XP computer has reverted to Windows Classic and does not allow any other options. I have tried all the obvious solutions, has anyone experienced ths problem and is there a simple fix?
    Novelist:
  • 169 Answers
I have experienced similar "abnormalities" after installing XPSP3 for some of my clients. My first recommendation would be to remove SP3 from Add/Remove Programs, reboot and see if that helps.
If you're concerned about the security updates, you can still get them from Windows update without downloading the SP3 pre-packaged "update", and just download them individually.
Hope this helps - remember to rate :)
Posted on Oct 24, 2008
  • 108 Answers
Go to control panel, administrative tools, computer management, services and applications, services, look for themes - if it is not started, start it - if it works, goto the properties of the theme service and set to automatic
G'luck
When i click on new folder option it does nothing
Which operating system ?
Restore Folder Options in Windows XP
Windows XP has several viewing options that you can modify for folders in Windows Explorer. These include being able to customize whether you activate items by clicking them once or twice, whether Windows displays hidden and protected files and several other options.
If you have played with these options in an attempt to determine how you prefer to use your computer, you may accidentally reach the point where you have changed so many items that you are unsure of how to revert to the original configuration.
For this reason, Windows XP allows you to restore the folder options to their defaults by clicking a button.
Open Windows Explorer.
Two of the fastest ways to do this are by clicking the "Start" button and then clicking "My Computer" and by double clicking the "My Computer" icon on the desktop.
Click the "Tools" drop-down menu and select "Folder Options."
Click the "General" tab, and then click the "Restore Defaults" button if you would like to restore the default settings for the "Common Tasks" bar on the left side of folders, whether new folders open in the same window or a new window and whether items open with a single click or double click.
Click the "View" tab, and then click the "Restore Defaults" button if you would like to restore any advanced view settings to their defaults, such as whether Windows displays hidden and protected files.
Click the "Reset All Folders" button if you would like to restore the default viewing option to all folders, such as the detailed view or list view.
Click "OK" to save your changes.
http://support.microsoft.com/kb/812003
May 18, 2013 | Compaq CQ56-219WM Intel Celeron 900...
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
Change screen orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Dec 14, 2012 | Dell Computers & Internet
My system now window7 .iwant instaling window xp .but no awaiable boot iwant driver
You can download the latest version (sp3 2011) of windows xp from this link:
http://www.world4free.in/2011/02/windows-xp-sp3-2011-v-1102-full.html
After downloading, place a plane CD in the CD/DVD writer and then double click the downloaded file. Now the burning process will begin. After burning is successfully completed, you can use this CD as your boot disc. Follow the installation procedure as usual.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jul 09, 2011 | Acer INTEL CELERON DUAL-CORE PROCESSOR...
About sp3
uninstall SP3 its extremely unstable.
Aug 09, 2008 | Microsoft Windows XP Professional
Acer Crystal Eye Web Cam
try reinstalling your camera driver
Mar 11, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
