Question about Electric Eyeware Razor Pocket Mod Bella Euro Girl's Electric Scooter
Inflating rear tire on razor pocket mod bella scooter
Where is the reset button at on the razor bella scotter?
there isn't one, but there are fuses by the battery that can be replaced
Jun 12, 2012 | Razor USA Razor Pocket Mod Electric...
Razor bella problems
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
Where is the fuse on bella
under the seat you have to remove the screws that hold the compartment on then this will give you access to the batteries and the fuse
May 21, 2012 | Razor USA Razor Pocket Mod Electric...
Bella won't charge
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
How do you operate Bella mod
there is an on/off switch right below the seat next to where you plug in the charger, then you have to twist the right hand grip
Apr 29, 2012 | Razor USA Razor Pocket Mod Electric...
Bought a razor pocket mod scooter second-hand-it needs a new inner tube in the rear tire. How do we get the tire off?
Use a wedge. Place the thin end between the tire and rim. Then push the tire off using the wedge and your other hand, work your way around the circumference of the tire until it is off. Use the same process to put the new tire on. But this time you will push the tire on the rim.
This is a pic of the ideal tool you should use:
Jul 08, 2010 | Electric Razor Pocket Mod Scooter
Electric Eyeware Razor Pocket Mod Bella Euro Girl's Electric Scooter Logo
214 people viewed this question
Top Electric Eyeware Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Electric Eyeware Toy Expert? Answer questions, earn points and help others
