Question about Garden
Replace starter rope on McCulloch MT700 - Garden
    Sergeant:
  • 316 Answers
Hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Posted on Feb 18, 2012
How do you replace starter spring on mcculloch 1.2 chain saw
If yours is not repairable, you can buy the whole starter housing , or just the starter parts to repair your starter assembly. The actual spring can be mounted on the starter spindle, and using strong clips, can be held in place or using vice grips to hold in place once the spring is tensioned , and in place. Then match the starter spindle over the spring. Next the starter rope, will have to rewind completely once it is installed back on the saw. If not, you can tension the spring by holding the rope at the starter spindle, and twist the starter spring about 4 to 5 complete revolutions clockwise, and then winding the rope on by releasing the spring . You can find videos on youtube and other online video services, to get a visual of what I described.
Jul 20, 2015 | McCulloch Garden
Why would the rope slip when you pull it the rope to start my mcculloch chainsaw but it does start
the starting clutch is slipping , this is not to be confused with the chain clutch (other side) reasons a start clutch slips , dirt inside /broken friction surface
May 22, 2014 | McCulloch Garden
Replacing rope on a strimmer
Check youtube for a video on how to place a starter rope on the starter cover of your saw. Once you see the visuals, if your pretty good with your hands, can see how they wind the spring , and place a new rope on the starter .
May 09, 2014 | McCulloch Mucculloch 330 Motor Housing...
Mac110/starter rope stuck, will not move
Remove gas and hold up,check spark plug.muffler may have gas,caused by needle in carb. sticking open.
Feb 08, 2013 | McCulloch Garden
Starter rope does not recoil when trying to start
Go to smalleng.com and you will see video section to fix your problem.
Sep 26, 2011 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Starter cord replacement
Here are the basic steps:
Prepair the new starter rope (about 5 feet of good qualty starter rope size 5.5) by burning the end and shaping into a point and tie a temp knot on the other end. Use a rag to shape the end because it will be very hot. Remove the old rope and align the hole in the spool with the hole on the starter cover and practice incerting the rope thru the guide hole on the cover into hole on the spool . This will be the final action after you wind the spool. You should be able to hold the spool and insert the rope thru both holes and tie a knot while holding the spool in a wound state. Once you have mastered incerting the rope thru both holes and tying a knot you are ready. Now begin.
Wind the spool in the same direction that the spool turns when you pull the rope. You must wind in the correct direction or you may bend the spring out of shape. The spool will begin to tighten as you wind and will eventually stop turning when the spring is fully wound. Once fully wound unwind spool one full turn and stop when hole on spool aligns with hole in cover. Now insert rope as practiced thru both holes and tie knot with free hand or have helping hand. Once knot is tied slowly let spool take rope in untill no more will go in or you reach temp knot. Now tie pull handle and you are done. Good luck.
Jul 17, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
McCulloch Mac GBV 345 starter rope stuck. Used
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Nov 22, 2009 | Garden
The starter rope on my 14PZ push mower broke. How
The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
Sep 27, 2009 | Garden
Return spring keeps on letting loose and doesn't work
Spring is broken. Sometimes hard to see. Hopefully is is at the end or close where the spring hooks to the housing. All you will have to do in that case is bend the spring and place back in slot. If broken in the middle, you will have to replace spring. Spring may be hard to find but you may find one on ebay or one of the saw forum sites. Just type McCulloch + the model no in google.
Apr 16, 2009 | McCulloch Garden
Garden Logo
362 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
