Instruction manual for goodmans GDVDR305DVBT
Cable set up whilst in use with tv and sky hd
ve3wtj
  • 147 Answers
SOURCE: dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Posted on Oct 07, 2008
SOURCE: Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Posted on Feb 16, 2009
  • 90 Answers
SOURCE: no sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Posted on Feb 24, 2009
railfan20
  • 20 Answers
SOURCE: Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Posted on Jun 01, 2009
  • 325 Answers
SOURCE: sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Posted on Sep 02, 2009
How do i tune my SAMSUNG PS42S5H for high definition channels
Does this model of TV have a built in HD receiver? I've had a quick look at the instruction manual and it looks more or less the same as mine at home. I've not got HD tv reception built in but have to use a set top box. If you're in UK, it should have Freeview HD sticker from the box or manual somewhere but as this looks like an early model tv (only 1 HDMI socket) then you may need a HD set top box such as Sky HD or Freeview HD
Oct 15, 2014 | Televison & Video
Why does the picture do this. Press sky on remote and all colours seem to b wrong but when tv button is pressed the pic is fine but not hd
If you are getting your video picture (t.v) through a cable box, satellite dish etc. you will have to adjust the internal settings of that box to match the HD settings of the T.V. as well.
Nov 27, 2013 | Televison & Video
My goodmans ld2271d tv has no control. When I set it up with the sky box it comes on but no sound , even on full volume. can anybody help? Could it be stuck on mute?
check the sound setting on the sky box go to setting, then sound. audio out stereo
digital audio out optical (dolby D)
digital audio output hdmi (normal)
digital audio output delay (0ms)
this is how the settings should be digital out put hdmi only works with full HD 3D tvs.
Oct 02, 2013 | Goodmans GTVL32W27HDF 32 in. LCD TV
GOODMANS LD3765D 37" HD READY ITS SOUNDS TINNY
Hello
Enter in this link, where you can download the user manual for your Goodmans Tv. It will give you all details about its settings..
http://safemanuals.com/brand-user-guide-instructions-owner-manual/GOODMANS
Nov 14, 2011 | Televison & Video
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
Sep 16, 2009 | Goodmans Televison & Video
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
