Replced convergense chips, 2 copper ring pull off board, installed tv powers up then shuts down. Can hear a klicking noise when powering up & one when it powers off. reading a 22 code?
  • 8,617 Answers
The rings that lift are what allows the ICs pins to be soldered into the circuit if the rings have lifted or are missing the set will not operate. It sounds as if you have a Mitsubishi with the 22 error code. Fixing the rings that lifted and double checking the pins to be sure none are bridged together with solder.
Posted on Feb 12, 2012
I have an Apex pf3230 32" TV that recently shut off, no power besides a slight clicking noise. The noise seems to be coming from a large component with a solid copper band about 3/4" wide... on said...
The short circuit protection circuit inside the set; detects a short circuit [shorted component/s]. The circuit shuts down the set; to prevent further damage to components. That is happening here. The sound you hear is from a cut of relay; which in turn switches off the set. Contact any service technician to detect the fault. Never switch the TV "ON"; until this fault has been rectified. It might make things worse. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 30, 2014 | Televison & Video
Philips 47MF437B Hi, this Tv will all turn for about 1-3 minutes then shut down. Any suggestions? Thanks
The tv is shutting down due to overload exerted on it by the components on a particualr voltage line. Possible locations are power supply board or the main audio/video board. The first thing you should check for are faulty capacitors on the two board. Look for capacitors that are swollen or cracked at the top. Even tiny holes at the top mean that the capacitor is faulty and needs to be replaced.
Nov 10, 2010 | Televison & Video
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replaced lamp in toshiba 46hm84. still get
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast is the most common failure besides the lamp.The ballast is the one that displays the lamp indicator if it's not able to power bulb or if bulb is not responding.Have a blessed one!
Mar 30, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
I remplaced the relay from the compressor but the frig dont turn on only make a klick noise on the power board
you need to replace the electronic control board where your hearing the clicking noise its bad,this is common for this unit model
Dec 14, 2009 | GE Profile PSS29NGS Side by Side...
I Have a Hitachi 42EDT41 and there is no sound and no video. I just put a new Power Supply in (@$90 delivered) and now I get a red standby light in front panel , when I turn it on the standyby light goes...
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV has gone on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage.
The clicking noise you hear is a protection switch that prevents the TV from starting.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Nov 08, 2009 | Televison & Video
Tv shut down and wont power back up, but circuits stay powered up
Check to see that the fuse is good. If so, test power supply. It is common for these to go out..
Sep 13, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
TV will not power on.
I guess your TV is DLP.
Please notice the follow symthoms:
When you on TV, did you hear some strange noise from the back of the TV. If yes, the color wheel needs replacing.
If no, check the lamp. Take a look to bottom of lamp, you will see white pot or sometime a pop up there due to lamp cycle is going to end. When changing lamp, check the ballast and power sup, too. If you see caps are poping up. Pull out those board and replace the poped caps.
Aug 13, 2009 | Televison & Video
Onkyo TX-SR 605 shuts of when i connect left front speaker
when i connect left front speaker it's shuts down .
That is probably due to protection caused by either
DC or over current. This means your troubleshooting is not complete.
Preform these steps.
Download SR605 service manual.
(a)unplug the amp.
(b)Connect left speaker (c)remove the vertically installed pre-amp board.
See this:
How to do?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
(d)Plug the amp and switch it on.
(e)If your amp stays ON forever, the problem is from this long board.
(f)If switch off at once, the problem is from power amp board.
Try the above- mentioned steps to confirm DC or over-
current in left channel.
(g)For DC protection, replace ALL components on left channel of the vertical board.
(h)For over-curremt protection, replace ALL components on left channel.
Replacing ALL components on a faulty channel do not cost you too much.
Feb 13, 2018 | Onkyo TX-SR804 7.1 Channels Receiver
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
