Question about Epson Perfection 1260 Flatbed Scanner
Need to clean the glass inside my Epson 1250 scanner. Is there an easy way to get in?
  • 291 Answers
SOURCE: needing epson perfection1250 driver for vista system
dowload the drivers of your device for 32- bit vista operating system from link below:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14548&infoType=Downloads
thanks and please do not forget to accept the solution
Posted on Apr 03, 2009
  • 19 Answers
SOURCE: Scanned pictures has thin blue line running through it
I had the same problem with My Espon Perfection V500. I called tech support and they had me do the following sequence.
1. Turn off the unit
2. Unplug the lid from the base
3. Replug in the lid.
4. Turn the unit back on
5. Go into the Epson software in Professional mode, Configuration, Other and select Reset All
6. Rescan the picture.
It worked after that. Of course it also lost all my preset sizes in my Custom box and any other settings I had. I suspect the lid plug is what the problem was.
Another word to the wise. To test it I put in a picture that was laying on my desk and rescanned it and was disappointed to see the line in the result. A few minutes later I discovered that this particular line was in the original picture.
Posted on Apr 18, 2009
  • 50 Answers
SOURCE: scanner epson perfection 1250 model g820a need power cable
Hi! You're looking for an ac power adapter. I'm including a link to a website where you can purchase one. Just click on the link, or if it doesn't work, copy and paste it into your browser's address window. If this helps, please rate this solution. Thanks! Hal
http://www.lcdpayless.com/productpage.php?productId=1208
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: problem with scanner epson perfection 1250 with
Today I installed VueScan on my Win7 (7264) X64. After that the 1250 was still not recognized. Go to start and execute/run devmgmt.msc. You will get the hardware list with a yellow marker on your scanner driver. Double klick on that icon. Now you need to go to the second tab (driver program if I translate it) and second button (renew if I translate it) where you can install drivers for the device. Tell windows to search on your computer and point to the VueScan directory (directly on C: , not in programs). Now Windows 7 (7264) X64 will find the driver and your Epson 1250 is recognized. :-) Tested and working.
This same method worked for installing the AlexP drivers for my PS3 Eyetoy on windows 7 (7264) X64. Also had to point manually to the AlexP dir and then the drivers dir.
I assume this method wil also work for Vista X64. Haven't tested this, I only have Vista X86.
Sorry for my bad english btw. Not my original language.
Posted on Jul 07, 2009
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
We need drivers to our Epson perfection 1250 model G820A scanner .
original drivers are always available on epson site and you can download th driver from there.
open the epson site/ select driver download option/put the model number of the scanner/ and do the free installation/
also alternately you can search the same in google.
May 09, 2010 | Epson Perfection 1250 Flatbed Scanner
The inside of the glass needs to be cleaned. How
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
Sep 29, 2009 | Epson Perfection 3170 Flatbed Scanner
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Jun 21, 2009 | Epson Perfection V100 Flatbed Scanner
I require instructions for using an Epson 1250 scanner
Hi
please check this link for scanner instruction
http://ftp.epson.com/pdf/pr125_/pr125_pg.pdf
or
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%201250%20SERIES-_E
you can scan any document in very easy way by the MS PAINT.
just type MSPAINT in RUN command then go to FILE menu then FROM SCANNER OR CAMERA
Thanks
Veeru _india
May 08, 2009 | Epson Perfection 1250 Flatbed Scanner
Installion for the epson perfection 1250 scanner
Epson website is the solution for your problem. You will be asked for the platform you are using, all you have to do is click the right platform and viola.. they will provide you the software you are looking for
Dec 04, 2007 | Epson Perfection 1250 Flatbed Scanner
Epson Perfection 1260 Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
