Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Message code on cannon copier
I have a code flashing...it says "waste ink near full". Any suggestions? thank you.
  • 34 Answers
You need to have the waste ink absorbers replaced, the cost of the absorbers should be around $20.00 and service is usually around 50.00. That is a very messy job, you must disassemble printer removed used/ waste ink pads in the bottom of machine reset ink counters and the reassemble printer.
Posted on Nov 11, 2008
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
My Cannon ip pixma 2000 is saying that the waste ink absorber is almost full how can i solve this
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Wast ink
Your MP780 printer has decided you have too much ink from the cleaning cycles in the absorbent pad inside the printer. Go to www.fixyour ownprinter.com and put "MP780 waste ink" into the search function. Follow the leads to find out how to clean the waste ink out and more important to find the code to reset the printer to get rid of the waste ink message.
Apr 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Waste Ink Near Full
Try this:
Waste Ink Tank Reset
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Let me know the result.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Office Equipment & Supplies
Message "Waste Ink Near Full"
1. Turn off printer
Thanks, Joe
Nov 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error (5800)
Waste ink is full counter reset.
Sep 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon f80 waste ink near full
See if THIS works.
Hope that fixed ya...
Geno
Mar 28, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
113 people viewed this question
old marine
old marine
Corne Viljoen
