Question about Garden
Why dose the Romero on the intake side keep falling off
What is causing the fuel pressure to fall?
Fuel pressure regulator on the side of the injectors. Or maybe a small leak somewhere.
Mar 06, 2016 | 1999 Chevrolet Tahoe
88 alpha Romero turn signals not working, license plate light not working and brake light well was able to get drivers side to work. Once I found a fried ground wire in trunk replaced. Please help
You should check all wires and connections as well make sure all bulbs are not burnt out. Check all your fuses as well. If you had one wire fried you could have others the same way.
Sep 25, 2015 | Cars & Trucks
Freeze plug location
Freeze plugs are located mid way down the engine block .
Below the exhust manifolds and above the oil pan.
If you have a V shaped engine their on bolth sides of the block.
Its rare to have a problem with them unless the block freezes although they can rust out and leak.
Their like a bottle cap pushed into the side of the block to keep it from cracking if it dose freeze.
The way to replace them is to drill a large enough hole in them to pop it out with a screw driver of course after you drain the block don't let it fall into the block it could clog the system .
Once you have it out drive the new out in its tapered so its an interferance fix tape it in but don't drive it to far so it falls into the block
Mar 15, 2015 | Cars & Trucks
I think I have an oil lifter problem. But my montana runs really well.
Hi Brie, Have you changed the engine oil regularly. Old oil can cause sticky lifters which sounds like your problem...
Oil changes every 5,000 miles are cheap insurance.
Nov 27, 2014 | Cars & Trucks
Avast dose not work and dose not let me uninstall it
try to re-install Microsoft C++ 2005 until 2010 again or re-install Microsoft.net and make sure that you are installing the latest version
Jan 28, 2014 | AVAST Software Avast Free Antivirus
Truck keep falling dead
air control valve on top of intake man.
Dec 04, 2013 | 2000 Ford Expedition
Ihave a 2005 kia optima the timing belt broke .I replaced and now it will not start .I try starting fluid and it hit but dose not start
sound like timing off.if valve timing off engine not going to fire.during intake stroke if intake valve timing off engine cant draw air and fuel in for combustion wont fire.
Jan 13, 2013 | 2005 Kia Optima
I installed a cold air intake on my 2010 mustang gt and it stales out and idols funny
1. check for a vacuum leak / bad -cracked hose.
2. check chock and chock linkage.
3. check carb butterflies are free to move fully.
4. check all carb linkage is free when you have your "cold air intake" on and the intake is clear and not obstructed.
5. how dose it run with out the "cold air intake" ?
6. did anything fall into the carb while making the repair?
Mar 25, 2011 | Ford Mustang Cars & Trucks
Heat gauge
Before getting too upset about this, try changing the temperature sender. Can't tell you where it is but it is usually on or near the thermostat housing but some engines have it on the intake manifold or rear of cyl head.
Apr 04, 2009 | 1993 Pontiac Sunbird
Rearlight assabley keeps falling
I HAD THE SAME PROBLEM WITH MY BIKE.. WHAT I DID AT FIRST WAS PUT BLUE THREAD LOCKER TO THE BOLTS. WHEN THAT DIDNT WORK I RELOCATD THE LICENSE PLATE LIGHT TO THE SIDE OF THE BIKE. THE ONLY THING IS TO JUST KEEP CHECKING THE BOLTS BEFORE EACH RIDE.. IT TEDIOUS BUT NECESSARY..
Mar 18, 2009 | 2005 Suzuki Boulevard M50
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
