Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
I have a Whirlpool DU1500 that makes a buzzing sound when it is on. Also, my dishes do not get clean and my the detergent dispenser does not open when the wash cycle starts
The buzzing sound is coming from the buttom of the diswasher.
  • 65 Answers
SOURCE: Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Posted on Feb 16, 2008
  • 185 Answers
SOURCE: Main Detergent Dispenser does not open during cycle
check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
Posted on Mar 31, 2008
reg501
  • 413 Answers
SOURCE: Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 13, 2008
mark_37388
  • 100 Answers
SOURCE: The detergent door doesn't pop open.
If you push the door closed not far enough to latch and let go of it does it spring back open if not the spring on the dispencer door is broken or has fell off
Posted on Mar 31, 2009
SOURCE: dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Posted on Jun 30, 2009
My 2003 kodiak just buzzes when i hit the starter buttom ?
charge the battery chk the wires it might be a bad starter
Aug 25, 2014 | Motorcycles
My kitchenaid diswasher will fill and drain with water but when the wash cycle starts there is a buzzing sound and nothing happens. Model 310253306 about 13 years old. The was cycle not working was not a...
The buzzing sound would be the motor trying to start and it not being able to turn...
either something is stuck in the pump and holding it from not starting or the motor its self has gone bad and will not start.
heatman101
Apr 23, 2011 | KitchenAid Dishwashers
It began with the dishes on the upper rack not being cleaned. Not the bottom rack is getting less cleaning done and some of the liquid detergent is left in the detergent compartment. I tried doing a...
Check your spray arms for pluggage at the slots and the nozzles. If you can remove them, do so and backwash them over the sink. Unplug the slots and nozzles with a toothpick or fine wire.
This should also help with dispensing the detergent, but reduce the amount to the least that you can use while still getting the dishes clean. We have cut our detergent usage to about 25%. Also, try to not place tall items where they can block the water spray to the dispensing compartment.
Use a good drying agent, and crack the door open when the washer reaches the end of the cycle, as this will help the dishes to continue to dry, and further release the steam, resulting in cleaner dishes.
The reduction of the detergent, along with the cleaning of the spray arms will help a lot. I should note here though that I've had to re-clean the arms after what I thought was a most thorough cleaning. Once they are really clean, they'll work better for a long time (usually).
Best regards, --W/D--
Feb 04, 2011 | Whirlpool Dishwashers
Powder detergent does not dispense into the dishwasher during wash cycle. The powder gets wet and stay in the dispenser and then when the drying cycle comes on it dries the powder and it becomes hard in...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 09, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
My dishes are not coming clean and when the dishwasher is finished there is still soap in the dispenser.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Sep 06, 2010 | Whirlpool Dishwashers
Need new buttom for folding my quinny buzz
You will need to contact Dorel UK. They are the UK agents for service/import. They will probably replace the missing button for you but you might find that you have to send the frame to them for repair. Costly unless you can ask the company you bought it from to send it on your behalf.
Jul 02, 2010 | Quinny Buzz Three Wheel Stroller
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Detergent is left in dispensers and dishes are not clean.
make sure you are getting hot water to D/W might also try different soap
Oct 26, 2009 | Dishwashers
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
53 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
