Question about Air Tools & Compressors
My wagner w640 sprayer leaks from the trigger
3 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
Posted on May 11, 2010
Testimonial: "Thanks for the reply Bigdex!"
#1 Taper
  • 1041 Answers
SOURCE: My Wagner 5.4 gph SprayFast
You may have a dirty tip. Try replacing it with a new one. Also check to make sure that you have it assembled correctly.
Posted on Sep 08, 2010
Can i thin Valpar Bond Primer no 46620 to apply with a Wagner sprayer?
If you have an airless sprayer yes , you can thin with a small amount of water or use flotrol for latex available at home depot or other box stores. If you have hvlp system no you can't. The hvlp uses a turbine wheel to compress air to around 3-5 psi. You did not say model Wagner sprayer you have. I use my Wagner to 1800-2000 psi. If the job is small you will have to consider the clean u time usually abound 30-45 minutes. Good luck
Jul 30, 2017 | Wagner Air Tools & Compressors
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
I have a wagner power painter 355E and the directions said to put oil in the 2 holes in the gun. Where are the 2 holes?
Where the raised tips of the tubing goes into the gun,
directions state ,"Apply a light coat of oil."Tip sprayer up side down (so handle is sticking up) and the underside where the two holes where the ditting dual hose go in there: This is where you put a small amount of oil into both holes and trigger the sprayer briefly
May 08, 2011 | Wagner Power Products 0154842 Medium Spray...
I purchased the Wagner power tex and loved it, recently it doesn?t spray with the ease as it did when I bought, I haven?t used it a lot only to do fill in?s, seems like it only releases the texture once...
Your sprayer is self powered? you don't use a separate compressor? I have one with a compressor and it has to be taken apart " the gun" everytime or the trigger becomes stiff. If it's self powered, I would say your mixture is too stiff and water and it should be fine..If not and if it's self powered, then your motor may not work properly.
Mar 17, 2010 | Wagner Power Tex Texture Sprayer #0520000
Air Tools & Compressors Logo
93 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
