Question about HP LaserJet 2840 Printer
How to get to HP Printer Toolbox
When I try to get to Toolbox - my browser says it cannot connect to the IP address: "Firefox can't establish a connection to the server at 127.0.0.1:5225". Same happens when I click on Utilities in the HP Director.
SOURCE: hp director
Issue
After installing Microsoft Internet Explorer 7 on the computer, the HP Director software window does not display when attempting to open the software.
Solution
The following solution works excellently for me. I had already tried updating drivers and re-installing the software but these steps had no result.
HP advises using the following workaround:
1.       Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2.       Press the Alt key and the Space bar together, and then select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar.
3.       Click HP Director on the Task Bar. The software opens and displays normally.
4.       Repeat Steps 1 through 3 every time the HP Director software is used.
NOTE: The HP Director window might appear a little smaller than normal, but the software is functional.
Posted on Oct 31, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Cant access HP DIRECTOR facility.
What operating system, Vista or XP?
Posted on Nov 30, 2007
checkitright
  • 1362 Answers
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try doing a cold reset first, then check that DHCP is manual not Auto. then try to input IP address again. If the Network card is seperate then you may only have to replace the Nic
Posted on Jul 16, 2008
SOURCE: HP LJ p2015dn IP configuration using HP Toolbox FX
Hi Basically I powered up the printer unplugged the network cable. Reconnected and waited 2 min. Pressed green button till first sign of green light flashing. The printer then printed out a printout which shows ip address on first and third page. I then used internet explorer to change printer from DHCP settings to fixed. just type new ip address on internet explorer address line. PC and printer must be on same network.
Posted on Jul 28, 2008
JackHeath
  • 1049 Answers
SOURCE: hp laserjet 4200 printer- how to find the current ip address?
On your printer go through the menu until you see jetdirect EIO, you should be able to navigate to the IP from there.
Posted on Aug 25, 2008
Reset IP HP2015DN
Hi, not sure why this is coming under the router section. You'd need to post a little more information about the problem. Is it with the IP address settings on your router or those wirthin the printer itself. If its
the printer itself - the problem solution is available here possibly.
But Google Resetting the IP address on
HP2015DN
Details To open the HP Embedded Web Server, type the IP address or hostname of the printer in the address field of a supported Web browser. To find the IP address, print a Configuration page from the control panel of the printer by pressing and holding the Go button for 5 seconds. The HP Embedded Web Server URL can be bookmarked for quick access at a later date. Supported web browsers include the following:
  • Internet Explorer 6.0 (and later)
  • Netscape Navigator 7.0 (and later)
  • Firefox 1.0 (and later)
  • Mozilla 1.6 (and later)
  • Opera 7.0 (and later)
  • Safari 1.2 (and later)
  • Konqueror 3.2 (and later)
The HP Embedded Web Server has the following three tabs that contain settings and information about the printer:
  • Information tab
  • Settings tab
  • Networking tab
Once the HP Embedded Web Server opens, perform the following steps to configure a static IP address:
  1. Click the Networking tab.
  2. Click Network Settings under Configuration in the left menu bar.
  3. Click the TCP/IP tab.
  4. Use the drop-down menu to change the IP Configuration Method to Manual.
  5. Type the new IP Address in the box to change the IP Address .
  6. Change any other applicable networking information, if applicable.
  7. Scroll down the page and click Apply .
  8. Click OK on the confirmation screen and then close the browser window.
  9. Wait a few minutes and then print the Self Test/Configuration page and the HP Jetdirect Configuration page to verify that the IP Address has changed.
Dec 03, 2013 | Computers & Internet
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
Tip
Printer IP Address Lookup
<span></span><b>Need assistance in looking up for your printer's IP Address?</b><br /><br /> Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it. <br /> <br /> 1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer. <br /> <br />2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following. <br /> <ul> <li>Start -&gt; Printers and Faxes, or Start -&gt; Control Panel -&gt; Printers and Faxes <li>Right-click the printer name, and left-click Properties <li>Click the Ports tab, and widen the first column which displays IP address of the printers </li></ul> 3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses. <br /> <br /> 4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -&gt; [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer. <br /> <br /> 5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
on Aug 05, 2011 | Office Equipment & Supplies
How do I find my ink levels? For HP Envy 110a
if you are using refilled cartridge, it wont show the level cuz HP wants your money for a new HP replacement.... if you look at lcd on printer and touch the icon with wrench you will see the ink level display or option somewhere, i forget exactlly but very easy to find.
good luck
Feb 24, 2013 | HP ENVY 110 e All in One Printer D411a
What is the IP address for my printer v305w i'am trying to connect it to my iphone
the DHCP supplied ip address currently assigned to the printer can be found by going into the network settings of the DELL Toolbox software.
Jan 25, 2013 | Dell V305w All-In-One R840635AU InkJet...
Hola someone tell me how to change up into proxy server help.
What is your default browser? Settings for using a Proxy server differs from each browser. For example, The settings for Mozilla Firefox browser are as follows,
  1. Click Tools->Options;
  2. "General", "Connection Settings";
  3. Select "Manual Proxy Configuration";
  4. Enter proxy IP and port to appropriate fields;
  5. Click OK to close Connection Settings;
  6. Click OK to close Options;
  7. Reload browser.
You must also be aware that the use of proxy servers without the express permission from the owner of the proxy server may be illegal in some states and/or countries. Use at your own risk.
Using a Proxy server masks your real IP address with a masked IP address. You can ensure this by visiting www.IP-Details.Com and check your IP before and after using a Proxy server.
Nov 12, 2012 | Computers & Internet
Tray setting of HP laserjet 1020 printer
This can be done i several ways.
If your printer is a network-model, you can enter the printers IP-address into your favorite web-browser and set the settings as you want from the web-interface.If your printer is a USB-model, you have to download the software for the LaserJet 1020. This package contains a software called Toolbox, and that's the software you need to set proper settings in your tray. Follow the link for downloading the Toolbox-package.
http://ftp.hp.com/pub/softlib/software8/COL14041/lj-39322-2/hp_LJ_1020-1022_Full_Solution.exe
Apr 20, 2012 | HP LaserJet 1020 Printer
How to assign static IP address to HP LaserJet P2035n
Plug the printer to a DHCP capable LAN. Give it a moment to connect. While the printer is on, hold down both, the feed and X buttons on top of the printer. It will print out a configuration page with the DHCP address. Type that address in a web browser. Click the network tab. Select manual address; then type the address you want. Then click save. DONE
Jan 25, 2011 | Computers & Internet
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 2840 Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
