Question about Nikon Coolpix 3200 Digital Camera
Camera got wet
Recently my Nikon Coolpix 3200 got wet and it will not turn on any longer. I disassembled it then discharged the capcitor and it turned on. I was able to turn it on and off for a few times, then reassembled it. At that point it would no longer turn on again. Any idea what the problem might be and how to fix it?
  • Anonymous May 10, 2009
    i left mine outside and the sprinkalers got it wet im charging it but still wont turn on !!!! HELP ME !
  • 31 Answers
You got it wet enough that you had to disassemble it? It's toast dude. Sorry.
Posted on Dec 19, 2017
5 Suggested Answers
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
sugarfree
  • 31 Answers
SOURCE: system error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Posted on Jun 14, 2008
  • 4 Answers
SOURCE: camera will not transfer images to computer. Maybe something wro
Just getting a car reader will be much easier than trying to take the Coolpix apart and repairing. Also your USB cord could be damaged.
Posted on Jul 22, 2009
  • 736 Answers
SOURCE: NIMH Battery goes off after 20 shots for Nikon Coolpix L01
the camera takes just about any AA pair of batteries ... lithium will give you the most pictures .. your NiMH batteries should last longer unless they are old .. you may have one weak battery ... you can try a pair of standard alkalines to see if there is something wrong with the camera .. if those work ok then you need a new set of NiMH ... there is a new type out called "eneloop" .. they are just like normal NiMH except they dont go dead when you store them .. even after a year they are still charged .. with normal NiMH batteries as they age they will self discharge in 2 weeks or so .. so you have to charge them just before you use them ..otherwise they go dead on their own .. if you charge them then not use them for a week then you will not get nearly as many pictures ... the eneloop batteries fix that .. you can also recharge them many more times than standard NiMH batteries .. they cost about the same ..
Posted on Oct 06, 2009
Nikon Coolpix 3200 won't turn on even when connected to computer via the usb cable
Disconnect the camera from the computer and put in a new set of batteries. Connecting the camera to a computer simply drains the batteries faster.
Feb 21, 2011 | Nikon Coolpix 3200 Digital Camera
I am trying to figure out how to shut off the flash on my Nikon Coolpix 3200 digital camera. Thanks!
Press cursor-up (marked with a lightning bolt) to bring up the flash menu. Select the lighting bolt in a circle with a slash through it to turn off the flash.
Oct 17, 2010 | Nikon Coolpix 3200 Digital Camera
Coolpix 3200. when i turn camera on, the lense
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Nikon Coolpix 3200 Digital Camera
Camera will not transfer images to computer. Maybe something wro
Jul 22, 2009 | Nikon Coolpix 3200 Digital Camera
System error showing up on Nikon coolpix 3200
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Camara not working
check is there enough battery? Try charging it for an hour or two and switch it on again.
Jan 03, 2008 | Nikon Coolpix 3200 Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
438 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
