Fios remote code for Curtis 326A - Televison & Video
4 Suggested Answers
  • 92 Answers
SOURCE: Verizon fios remote
Akai 0057, 0087, 0699, 0729, 0839, 3002, 3182, 3219, 3247, 3248
Posted on Dec 15, 2008
SOURCE: Sylvania remote no taking Verzon fios codes
I had the same problem, the only way I was able to fix this problem which drove me nuts, was to by a learning remote.
I bought a nice Sharper Image Large Remote with lited buttons for $15.00. It did the trick, and will learn any remote and it's buttons.
Posted on Dec 30, 2008
SOURCE: coby tv code for fios remote
1. Press and hold the TV key. 2. While holding down the TV key, press OK. 3. Release both keys. The Device Keys will blink twice.
Ideally we do not have code for coby TV. So we need to manually program the remote
TV and Cable box should be both powered on.
4. Press 9 - 2 - 2. 5. Point the remote at the TV. 6. Press PLAY Press FAST-FORWARD. Every time you press FF the remote sends out a new power-off command to the TV. Keep pressing FF until the TV turns off. (You can press REWIND to go back 1 code.) 8. When the TV turns off, you have found the right code. Press OK to store this code. 9. Press TV and the power should go on. You will now have volume control also.
TIP: Press ff slowly so you know when it powers off and when you need to save the code by hitting OK after it powers off.
Posted on Feb 20, 2011
Can i manually add channels?
Refer its user manual for details.
Sep 26, 2013 | Curtis 326A LCD TVDVD Combo
Cant find remote control for a curtis tvdvd 326a-2
Check these codes. 000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109. If you wish to get more codes, check this link.
Feb 23, 2013 | Curtis 32 720p Lcd Tv Factory Recertified
Have a curtis tv , trying to run autoscan, it runs, but it doesn't locate any channels. I have a comcast converter box also. Not sure why autoscan isn't working. Or do I have to set up my comcast...
For the auto scan to detect there must be channels present on the CABLE that is connected to the RF input- TUNER INPUT- of the TV.
So check with your cable operator for the channels and you can connect. however if you are using a digital box then the channels are memorised on the box as only the output of the box is connect to the video/audiop inputs of the TV. if so select line in/video 1/2.
Oct 18, 2011 | Curtis 326A LCD TVDVD Combo
Curtis lcdvd244a fios remote code
I called curtis for the remote codes they are as follows 1218 2622 2295. They told me they might work. But the said they might not on univerasal remotes. I am going home and tryin them on my comcast remote.
Sep 18, 2010 | Televison & Video
I have a curtis Mathis flat screan television and am trying to program my verizon fios remote control to operate the television as well as the fios box. I tried every code that is listed in the verizon...
Since I can't find anything about your set except the fact that it's an older set I suspect that the trouble lies in the fact that Fios won't control a set this old. I do believe this one has an analog tuner which is now obsolete.
Regards
Jun 19, 2010 | Curtis-Mathis CM32010 TV
Remote comtrol
Depends on the make of your TV. Here is a link that shows, step by step, how to program your Fios without a code.
http://www.ehow.com/how_5066834_program-fios-remote-code.html
Sep 29, 2009 | Computers & Internet
FIOS remote will not activate Sylvania TV.Tried all codes listed for Sylvania.Customer Service no help. Any suggestions
Does the package the remote came in say it works with this brand? If it does and it still don't work, you can either google fios remote codes for further lists of more codes, or buy a different universal remote.
May 30, 2009 | TruTech PLV1615T 15 in. LCD Television
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
