Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC-9420CN maintenance mode - Brother MFC-9420CN All-In-One Laser Printer
4 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: BROTHER MFC-3240C
The printhead cant travel without prob in its rail. Try to pick up the paper which might stuck somewhere.
Posted on Oct 22, 2007
Mix-it-up
  • 832 Answers
SOURCE: MFC-9420CN
There is no 9 4 2 0 cn machine from brother.
Anyway if you run a ink printer from brother have a look around here:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000053/faq000253_008.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=16
Posted on Dec 05, 2007
SOURCE: Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
brother mfc9420cn factory reset
Posted on May 30, 2008
The printer wont printer and displays "Unable to Print. See Troubleshooting and Routine Maintenance Chapter in Users Manual"
Unplug the printer for about 15seconds and then plug back in and power up.......this should reset the error code! Test print and you should be good to go!
Oct 05, 2014 | Brother Mfc9420cn Mfc-9420cn Fax Modem...
Brother mfc-9420cn unabel to scan
I work at Office Depot. Bring it to one of our stores and we can look into it and diagnose it. Usually it is as simple as a loose toner cartridge.
Dec 14, 2011 | Brother MFC-9420CN All-In-One Laser...
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
Mfc-9420cn scan button does not initiate a scan
You should switch to scanning mode on the printer's interface!
Jul 15, 2009 | Brother MFC-9420CN Laser Printer
Change time on Brother MFC-9420CN
laoding is too slow, It did very fast but now is too slow what happen?
Mar 31, 2009 | Brother MFC-9420CN All-In-One Laser...
Error message says "no paper" but there is plenty of paper
I had this same problem,
Here's what did it for me:
1)Power off the machine
2)As you hold the 'Menu' Key down, turn the power back on.
(this will take you to maintenance mode)
3) Press 91 to do a parameter reset
4) Press 99 to exit maintenance mode.
I hope this helps you as it did me.
Mar 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother MFC 9420cn "unable to print see troubleshooting...users guide"
ctstore,
Your unit requires replacement of its maintenance kit. You will not be able to do this by yourself unless your are a technician, which I assume you are not. The cost for this repair will not be cheap, you are going to be up for over $500 and you need to do it through a brother warranty service centre.
Gremlin11
Sep 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Mfc-9420cn
Did u do the whole reset thing? 1 and 7 together and 2 and 8 I think, Just reset the settings also in the menu. Then do the whole maintenance Ma-Jobby, menu then mono-start then up arrow 4 times, u must be quick however.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Mfc 9420 brother
Same problem, went through the entire printer, removed all parts and it started working. Next day the same message
Oct 25, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
59 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
