Question about Home Security
I have a SB0500 Sentry Fire Safe, Number AU-932969 the manual was destroyed in a fire and we no longer have the factory code or the combination. please help?
We purchaced the sentry safe to protect our documents from fire, which it did. but in the fire we lost many things, one of them being the manual, it had the factory code and the code we had programed. since we no longer have the factory code we can not open it. Does anyone know the factory code for this safe, or how to by pass it? any help would be useful. Thanks
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
Posted on Jul 09, 2008
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
Model 1310. How do I recover from lost combination?
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupFor over 80 years, SentrySafe has built fire-resistant safes that provide security ...Combo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership ... the notary process if you do not have your username, password, or combination. ... An override key is needed to unlock the safe.Missing: question
' Sentry® Safe ' SFW
Dec 18, 2015 | Sentry Safe Fire-Safe Home/Office Safe
Loss the manual combination of my SENTRY SAFE SFW123DTB a1205009
Dear Marianne,
You need to call Sentry Safe. Give them the serial number and will give you the Combination or a new one.
Here are 2 links to the operation manual.
SentrySafe Fire Safe Owner Manual
Good Luck!
JP
Jul 03, 2015 | Home Security
I do not remember the factory code for my sentry safe sb0500 and need to change the cold
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Feb 18, 2013 | Sentry Fireproof Safe
How to open or override my 1960's sentry Combination safe
Your only solution if you can not find your owners manual it is posted in is to order keys and combination from the serial number on the safe or drill out the locks
Jan 06, 2013 | Sentry FIRE-SAFE Combination Safe DS3431,...
Need factory code for sentry gun safe
Dec 21, 2012 | Sentry Fire Safe 24-gun Safe Combination...
Lost factory code for sentry safe model #d8W5840
did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost.
Check the attached links,instruction and guides on how to open your safe. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SFW123CS Combination Fire Safe
http://content.etilize.com/User-Manual/1027349209.pdf
How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431...
Emergency Locksmith Services Aim Lock Safe
Jan 21, 2012 | Sentry FIRE-SAFE Combination Safe DS3431,...
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 18, 2009 | Sentry Fireproof Safe
Lost combination
A good locksmith can get into this for you. Since it's fire rated, the case is soft or at least thin. A burglar rated safe is solid steel, but a fire rated safe is thin plated with a fire retardant filling.
Ken
Aug 18, 2008 | Sentry Home Security
Home Security Logo
115 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
