Question about RCA D52W23 52" HDTV CRT TV
Rca tv stuck on mute - RCA D52W23 52" HDTV CRT TV
We moved our big screen rca and now the volume
Go to..Menu" on your RCA REMOTE...click on..audio..Check that it's..NOT on ..MUTE"...or.."CLOSED CAPTION"....:)
Aug 28, 2014 | Computers & Internet
RCA Tru Flat 20" TV/DVD Combo Remote and manual
Hi
Check its speaker first. If it is Ok, check whether the volume is set to zero, or mute function is ON. If all of the above is OK, the audio output IC of your tV is faulty. You ahve to replace it with same type and number. Audio IC can be located by following the speaker wire. One end of that wire will go to oudio output section. There will be an IC; usually screwed on to a metal heatsink. Check its solder terminals first, for any loose soldernng. It is best to resolder all the solder terminals of that IC, by applying a little more solder, without making any solder bridge in between adjecent solder points. If this resoldering also does not help you, check the voltage at the pins of that IC. The maximum voltage will be between 25 and 24VDC. If the voltage also is there, and still there is no sound, replace the IC with same type and number, provided the speaker is good. OK.
Jul 12, 2011 | RCA 20F610TD TruFlat TV/DVD
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
No sound to TV when MUTE button is turned off.
eeprom ic after you replace it you will have to have service menu to reset hori sink .
Dec 12, 2008 | RCA F32665 32" TV
MENU COMES UP AND MUTES ITSELF
check to see if your remont control dont have the mute button blocked down
Dec 11, 2008 | RCA MM32110 TV
How do you mute tv but not headphones?
Look in your TV's menu options. I have an RCA TV which allows me to turn on (or off) the headphone port and set the volume of the headphones. Once you turn the headphone volume up, then you can turn the TV Volume all the way down with your TV remote while the headphone volume remains where you set it. Hope this works for you.
Feb 13, 2008 | RCA WHP141 Consumer Headphones
Sound
try to buy universal remote.. available in all market..
Jan 01, 2008 | RCA F19281 19" TV
ON/OFF
turning off mute with no remote on a rca reciever
Dec 23, 2007 | Televison & Video
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
Control Panel
Yes you can replace the chip, BUT, first try to clean the button contacts. I have to do that to my remotes, phones, and RCA TV (yes I have one too) etc.. around my house. Just needs a good cleaning. Don't forget to unplug the TV.
Jun 30, 2007 | RCA 32V550T 32" TV
RCA D52W23 52" HDTV CRT TV Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
