Question about Coffee Makers & Espresso Machines
What cleaner do i use to clean the bottom of my non stick stainless steel pan..the bottom turned yellow..the inside is sticky
  • s.bosc Feb 11, 2012
    IT WASNT A OOFFEE POT//IT WAS A PAN THAT TURNED YELLOW ON THE BOTTOM STAINLESS STEEL,COOKS ESSENTIAL FROM QVC
  • 26 Answers
Try soaking overnight with a strong solution of bicarb, say 3 tsp in half pint. Won't do your finish any harm.
Posted on Feb 11, 2012
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
Mar 21, 2013 | Cook's Essentials CooksEssentials 3 Quart...
What are frying pans made out of?
They can be made out of a lot of things but most are copper, Teflon or tin.
Jan 10, 2013 | Home
Cleaning
purple power or clorox Can get both at the dollae store
Feb 11, 2012 | Coffee Makers & Espresso Machines
How can we clean the baked on food from the oven racks and rack holders? Stainless steel cleaner does not touch it.
To clean the stainless steel without marking it you can first try non-caustic oven cleaner, if you use normal oven cleaner the acid in the cleaner will etch "eat" the surface of the stainless steel
May 05, 2011 | Electrolux 30" Built-In Single Electric...
I have the porcelain coated pans and the kids burnt chilled cheese and just can't seem to get it clean now
You can use spray-on oven cleaner, such as "Easy Off" or any similar store brand. Do not use oven cleaner on Aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubber handles. Wear rubber gloves when working with oven cleaner. It is a very powerful cleaner and can burn your skin.
  1. Put the pan in your empty kitchen sink.
  2. Spray it on generously with oven cleaner.
  3. Leave it overnight, 8 hours or so.
  4. In the morning thoroughly rinse and wipe all the areas you sprayed, including the sink.
You should have a clean pan and a clean sink. Refer to the oven cleaner's label for further instructions and safety hazards. Choose the type of oven cleaner that suits your needs. In my experience, "Fume Free" oven cleaners take longer and don't work as well. Seemingly, the more noxiously fumed cleaners, ie ones containing Lye (Sodium Hydroxide), work better and faster.
This works for porcelain coated pots/pans, stainless steel, steel, glass, etc. Do not use oven cleaner on aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubberized handles.
Apr 02, 2011 | Vacuums
I want to change from a white door panel to a stainless steel front on dishwasher. kenmore model 3 16374300 . Where do I order the front.?
Warner's Stellian in Saint Paul can help for exchange. For cleaning stainless steel we reccommend DeBruce Polish. The "green cleaner" DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more.
We buy DeBruce at debrucepolish.com.
Dec 13, 2009 | Kenmore 24 in. 15173 Stainless Steel...
Scratched stainless steel
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
Mar 29, 2009 | Kenmore 99123 Electric Kitchen Range
Having trouble cleaning splatters off Ingis Glass Top Stove.
Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
debrucepolish.com
Jan 13, 2009 | Maytag MER5730 Electric Kitchen Range
Streaky stainless appliances.
Hellocmmirabile,
Welcome to Fixya,
You asked, What do you use to clean stainless appliances so they won't streak?
At this site of our sponsor, they have a good stainless steel cleaner.
http://www.pcappliancerepair.com/cleaners.shtml#cleaners
Stainless Steel Cleaner - 10 oz
P/N: 31462 Stainless Steel cleaner made by Whirlpool. Cleans and polishes stainless steel. Non abrasive and residue free. 10 oz bottle
Availability:
In-Stock $ 6.99
I use a $1.00 bottle of alcohol from the dollar store,
which is already mixed with water 80-20% OR or 50-50 %.
What ever they have available and I do it twice.
Let me know how you do.
Thank You for using our site.
Huuum,
Please remember to leave a solved rating at fixya
Oct 21, 2008 | Stainless Refrigerators
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
