Question about JVC AV27F476 27" TV
White screen and sound
I switched my TV on to find that the screen was all white with no channels working all were the same. I have sound and when I switched to Teletext, it was fine.
    New Friend:
  • 163 Answers
Sorry but you got a video circuit problem and this require special tools an equipment get a tech.....good luck
Posted on Aug 09, 2006
SOURCE:
My emerson LF391EM4F tv has a white screen
Most likely the T-Con board has failed.
Jan 26, 2017 | Emerson Televison & Video
Why does my TV on when the power button is off?
You need to spare yourself a lot of frustration and just replace the TV
Jul 13, 2016 | Astar Magnavox 19MD358B 19 in. LCD TV
Have an Lg tv that when turned on has a white screen. Model # LX6500-UB.
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 25, 2015 | LG Televison & Video
White screen
It sounds that the digital processor section to video at the main board is faulty. Contact any service technician.
Jul 01, 2013 | Pioneer Elite PRO-151FD 60 in. Plasma TV
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Magnavox with a white screen, sound, volume and channels working
dont put in back the vertical prossesor ic get a new one and solder it in see what it does.good luck.
Aug 19, 2008 | Philips Magnavox 27MS343S 27" TV
No sound on just one channel
Do you have another TV in house that works with this channel correctly? Do you have a VCR (or VCR/DVD combo) that you can use to tune to this channel? I'm wondering if your tuner is going bad on this one channel. Do you have SAP (Second Audio Program) turned on? You may want to turn it on and then check channel for sound. I'm assuming that you're getting your cable feed thru coax and not composite (red & white audio). If you are using composite, try switching the red & white inputs to see if sound comes in. It's possible that cable company is only outputting audio on left or right channel and something is wrong either with one of your TV's speakers or with the cable company's output.
Mar 06, 2008 | Orion STV2763 27" TV
Philips 17pf8946/37 has no video
Phillips LCD TV 17PF8946/37, has no picture at all on the screen, even menu and channel #s not showing in the screen. The screen just have blue color. Everything is working like switch & video. Please let me know what parts need to be replaced and where can I order the parts.
Nov 15, 2007 | Televison & Video
After 2 years of use, screen on TV went to white but sounds still works
Hi Sounds to me like the Tuner Module went out, this is something a qualified technician would have to fix.
Mar 08, 2007 | Apex Digital PF2720 27" TV
JVC AV27F476 27" TV Logo
44 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
