The bar brush no longer spins when I turn it on. It used to happen when too much hair accumulated on it but it is completely clean nowand still doesn't spin.
I'm sorry to hear you're having difficulties with your Dyson. I can't provide specific advice as you haven't stated which model of Dyson you own - but if you call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), we should be able to resolve this issue with some troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
SOURCE: brush bar not spinning
Depending on the make and model the belt may be bad or if it has a clutch assembly then it has gone bad.
SOURCE: The brushes won't spin. I
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
SOURCE: brush inside main head doesn't spin, and stops
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
