Question about Radio Communications
Unstable freq counter on galaxy saturn - Radio Communications
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
What do you mean unstable ? Is it flickering ,does it have pieces of the numbers missing ,What is it ????
Posted on Jan 12, 2015
SOURCE: Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Posted on Apr 30, 2009
  • 67 Answers
SOURCE: connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
Posted on May 25, 2008
  • 181 Answers
SOURCE: my freq counter didnt work on my galaxy dx 959
check patch lead with multimeter both centers and outers should read but inner and outer togther should not. try a power meter to make sure you are tx ing at least 1/4 of a watt. try freq counter on another rig. all rigs will run on a counter.
Posted on May 14, 2009
  • 25 Answers
SOURCE: I'm looking for someone who can tune a Galaxy Pluto
Sparky's CB Shack does good work. Depending on your location, you may have to ship it to them.
Posted on Jul 17, 2009
kb8dns
  • 494 Answers
SOURCE: i have a galaxy saturn turbo that is in tx as soon
The T?R diode or transistor is shorted, this requires a technician to make repairs, I do not recommend home repair on this type of fault....
Posted on Mar 07, 2010
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
Galaxy dx 2517 frequency drifts sometimes on recieve and sometimes while talkng freq will go both ways up and down
The mixer crystal is unstable. It may need replacing. Some times you can reset them. Take a soldering iron and heat up the mixer crystal up for about 5-7 seconds. See if this stabilizes it. If the radio still drifts,then you need to replace the mixer crystal.
Nov 23, 2010 | Galaxy Radios DX-2517 CB Radio
Band selection an freq. doesnt align galaxy 33hml
sounds to me someone was tampering with it ,your best bet is to get a frequency counter and realine the radio .start from 27.185 centre band you can do this by tuning the ossolator be very careful not to damage this should realine the radio for you goodluck
Oct 16, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
My freq counter didnt work on my galaxy dx 959 when i took it out of the box and hooked it up.. what do i do about this and is this common thanks drew
Apr 04, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Radio Communications Logo
124 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
