The piezo ingiter will not spark - Heating & Cooling
    Problem Solver:
  • 13 Answers
Are you holding the ingiter button for about 4 or 5 minutes before trying to light
Posted on Feb 12, 2012
Chef Regency Gas Wall Oven - oven fan working,light working , grill working as well but the main oven not responding when turning dial. The Piezo ignition is intermittent and no gas sound coming out.
The Piezo control board opens the gas valve while it makes a spark. Once the flame is lit the milivolt flame sensor holds it open from there on. Replace the piezo control board to fix.
Jan 16, 2016 | Kitchen Ranges
No spark visible through mica glass inspection cover when piezo igniter button is operated.
Piezo igniters can fail for a few reasons. Often they short or spark in the wrong place. Sometimes they can be corroded. Try cleaning it and see if it will spark. Otherwise, you might need to replace it or just use matches. Is your heater under warranty?
Jun 11, 2015 | Water Heaters
Oven , grill won't light
If Piezo , check that you have a spark. The Piezo can fail , but it's rare. If no Spark, then replacement Peizo needed.
For Help call e-spares
Phone 0844 9777 888
Website www.espares.co.uk
Feb 24, 2015 | Kitchen Ranges
No spark when pressing piezo on free standing gas stove lake field model from cozy heat
https://www.youtube.com/watch?v=PicYiwm-VSk
This you tube clip may help ....
Your issue may indeed be a broken piezo ... or as the clip indicates ... cleaning the tip of the piezo could help or there may be a broken/loose wire somewhere in the circuit.
Good luck on your troubleshooting!
Jan 09, 2018 | Kitchen Ranges
Bosch aquastar a125b piezo wiring diagram
Piezo igniter only needs 1 wire to cause spark.
The other wire might connect to electronic gas control to report error, but brand type and age of product is not described in question.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene h
Mar 18, 2014 | Water Heaters
Radiant heater, natural gas. Piezoelectric starter seems to work perfectly, nice healthy spark, right where it should be. Gas flows like it should but it doesn't light with the piezoe. It lights right away...
Disconnect (pull off) the wire from the piezo pin on the bottom of the piezo, then slide it back on. If it had lost it's ground,which I think it did, that should solve the problem.
Mar 23, 2011 | Heating & Cooling
GAS hob keeps sparking when pluged in
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter
Jan 18, 2011 | Cooktops
My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
Feb 25, 2010 | GE JGBP28 Gas Kitchen Range
My dacor grill wont ignite. I has to getting
The lights are run off of a transfomer that plugs in to a 110 outlet. The ingiter, most likely, runs off of a battery. If you can unscrew the cap on the igniter, there may be a AA or AAA battery behind the cap. If there is no cap, just a button, then there is probably a 9 Volt battery somewhere on the unit. If you have a single spark piezo igniter there will be no battery, they just wear out over time.
Jan 25, 2010 | Dacor Epicure EOG36 (LP) All-in-One Grill...
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
