Question about Toshiba DR-430 DVD Recorder
How to hook up a dvd recorder and dvd player to digital cable and tv
I want to hook up my Toshiba DR 430 Dvd recorder & my Sony DVD player to my cable & tv. How do I do this?
night71
  • 328 Answers
SOURCE: toshiba dvd recorder #rd-xs35
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35
The cable box hook-up is on page 22. There are two ways: 8bc47e0.jpg
Posted on Oct 25, 2007
SOURCE: S-video imput not working
I had the same problem. Solved it by going to Set Up, Video Selection, then choosing the S- Video input jack, vs the default. Now if I could just get it to pass video when the unit is off...
Posted on Dec 28, 2007
SOURCE: We hooked out Toshiba SD-V291
I just had the same problem, and I am using rca blue, red and green cables for video. I unplugged them and plugged them back in again a couple times and it finally worked. I have had this problem before with another dvd player, don't know why. Hope this helps.
Chris
Posted on Jan 09, 2009
Tech5508
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Posted on Feb 13, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Posted on Jun 25, 2009
Toshiba dr 430
hard disc may be corrupt, format the hdd to completely erase it this may fix it
Mar 29, 2014 | Toshiba DR-430 DVD Recorder
Connect jvc dvd to zenith tv
just hooked up with an rca cable from the output jack ( audio/video ) of your dvd recorder then the other end connect to the input jack of the tv. then set your tv at the same time the dvd player to record.
Aug 11, 2012 | JVC DR-MV150B DVD Recorder/VCR
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
I'm having trouble hooking up Toshiba DVD, HD cable box and TV.
first is this DVD recorder? its not okay plug the wires from DVD to tv (left / right and video -digital in or av1 in) cable box is connected to tv (red/blue/green) tv should be on component (source)...to view dvd switch to av1 or digtal1.......if this is a recorder get a coaxial cable and connect from cable box out to DVD in (the TV setup stays the same as above) DVD set up should be on CATV/ch 3..........the out connection is the same as a reg player (see above)
Aug 28, 2010 | Toshiba Televison & Video
I need to hook up the dvd player to my new Sony
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
Jul 19, 2010 | Sony DVP-NS50P DVD Player
How do I hook up a dvd recorder, dvd recorder/vcr combo and a vcr to a anlog tv with only two inputs. VCR combo has no cable input/output
If there's a spare place for the DVD to be plugged into the telly and a spare place for the DVD player to slot a cable in then buy a cable off ebay for around $5 and then connect the cable to the devices holders on the telly and DVD player.
Hope I helped Dr Reed
Apr 06, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Since they switched to digital TV, my VCR/DVD player will not record a TV program.
The DR-MV150B has both a digital tuner and analog tuner. Since the digital conversion you more likely have not run a channel scan for the new digital channels. Plugging in a digital tuner would work, but is unnecessary. What you probably have to do is run the 'auto scan' feature through the recorders menu. Hit "Home" button go to the "TV" icon and select "Auto Scan". It will take a few minutes, but recorder will scan for digital channels and memorize them.
Aug 13, 2009 | JVC DR-MV150B DVD Recorder/VCR
Jul 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Apr 27, 2008 | Sony SLV-D350P DVD Player/VCR
Toshiba DR-430 DVD Recorder Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
