Question about Brother SE-270D Computerized Sewing Machine
My Brother Embroidery machine is making a grinding noise, I have thoroughly cleaned the bobbin race area, threaded, and re-threaded it, changed thread, bobbins etc with no success. The handwheel appears to be jamming too. Any help to remedy this would be greatly appreciated. Model: NV750D Product Code: 885 - U33
  • Anonymous Nov 05, 2008
    I am not sure where to oil my sewing machine at
  • 46 Answers
I would take it to a mechanic.
Posted on Oct 24, 2008
When sewing I am getting a clicking noise with each stitch. I have change bobbin etc. What is this?
Have you installed a brand-new needle? Usually, a bent or damaged needle will make strange noises. You can probably open the bobbin area and hand-rotate the handwheel and watch the needle action. Could be the needle/hook timing is off and the needle is nicking as it lowers to pick up the bobbin thread.
May 02, 2016 | Brother SE-400 Sewing & Embroidery Machine
Why does the bobbin keep showing up on top of the embroidery? I have changed the bobbin, I have rethreaded the top thread, I have changed the needle, I have cleaned the bobbin area. How else can the...
Loosen the top tension a little or tighten the bobbin tension ever so slightly. If that fails you can always color the bobbin threads with a magic marker the same color as the embroidery thread. You might go to Superior Thread's web site and try some prewound bobbins. They are worth their weight in gold. Dr. Bob knows all about all kinds of thread and is very good about answering questions. I think some of his Thread University videos are available too.
Jul 15, 2014 | Brother PE-770 Embroidery Machine
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
E4 message
contact singer customer service about the error code e4, the resistance could be a broken or damaged part.
Mar 22, 2014 | Singer Sewing Machines
Clunking noise from sewing machine
Would need a good look to know whats wrong sorry the bad answer but a sowing machine with clonk ?? could be anything
Jul 05, 2013 | Brother HE-1 Embroidery Machine
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
I have a Brother Se 270D sewing/embroidery machine. It makes a terrible grinding sound and won't go all the way up or down. I have removed the thread, bobbin, and bobbin case and cleaned all of...
Take it in for service, hopefully it is still under warranty, I have sneaking suspician that your motor is causing the problem. I had a machine that did that and it turned out to be the motor.
Apr 20, 2011 | Brother SE-270D Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
397 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
