Question about JVC BR-DV600U Mini DV VCR
How do I connect a JVC BR DV6000 TO AN Apple iMac
Solutions for connecting jvc br dv6000 to an imac 27" to work with final cut pro 7.
jomaru
  • 337 Answers
SOURCE: tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Posted on Oct 17, 2006
  • 221 Answers
SOURCE: miniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
Posted on Jul 02, 2008
mistersony
  • 320 Answers
SOURCE: JVC BR-DV3000 Mini DV-DVCAM issue
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
Posted on Nov 08, 2008
  • 221 Answers
SOURCE: I have a JVC BR-DV3000 that keeps stopping my tapes while playing
try a hand cleaning - seek out a good technician.
Posted on Aug 05, 2009
SOURCE: I purchased a JVC BR-DV600U DV deck to use with my
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
Posted on Feb 05, 2010
MY IMAC DESK TOP HAS CRASHED I WAS TOLS IT WAS BY CIGERRET SMOKE HOW CAN I FIX IT
Only way to fix it is take it to a professional, like myself and they will be able to tell you what part is bad on your computer.
Jun 02, 2014 | Apple 2011 27" Imac 3.1ghz 8gb Ram I5 1tb...
Tip
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP...
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac.
Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac.
Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos.
Step 2. Choose Apple ProRes codec for Final Cut Pro.
Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.)
Step 3. Merge Canon MXF files. (Optional)
Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output.
Step 4. Convert MXF to Apple ProRes MOV for Final Cut.
Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio.
After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jun 16, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
How do I import from JVC br dv3000 into Final cut or imovie
You can learn the guide on http://support.apple.com/kb/HT1096, see how to import video from a camcorder or camera, but you should sure the format of your video is supported by imovie or final cut pro, if don't, convert video to imovie first.
Nov 23, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Connecting an external monitor via the imac g3 vga port
The G3 iMac, to my knowledge, does not support an external monitor.
Nov 11, 2012 | Apple iMac G3 Desktop
IMac does not recognize jvc gr-d22u camcorder
It will not appear as an attached hard drive. If you access it through imovie you should be able to access it. The article here should give you some pointers on the process http://www.iskysoft.com/article/import-camcorder-video-to-mac.html Hope this helps.
Dec 23, 2011 | Apple iMac Z0GF0005F Desktop
While trying to install OS10.5 and it will attempt to but it freezes, you the Apple booting circle it stops.
Probably the OS 10.5 version your're installing is not compatible or supported by the system motherboard of your computer model Apple Power Mac G5. per my research from Apple website herewith is their solution quote on what applicable OS to install for such model: "Power Mac G5 (Late 2005) and iMac G5 (iSight) models require Mac OS X 10.4.2 or later, you can t install Final Cut Pro 3.x or earlier versions on these computers. Final Cut Pro 3.x and earlier versions are not supported on any computer running Mac OS X 10.4". best regards
May 20, 2009 | Apple Computers & Internet
Problem transferring video from JVC JZ-HD3E-Ek
the stills use the USB and usually video needs firewire, do you have a port marked ieee1394, i-link or firewire?
Mar 29, 2009 | JVC Everio GZ-MC200 Camcorder
Transfer JVC GZ-HD7AATOD Files into IMAC IMOVIE 8
download tod converter for mac program, which allows you convert .tod file into imovie understood video, mp4, mov, dv, etc.
Aug 12, 2008 | JVC Everio GZ-MG27 Camcorder
JVC Everio HD3 - video format problem for MAC
Have a look at http://software.transdigital.co.jp/products/cbs_ev/qc_eng/index.htm
There are instructions and links to solve the problem
Mar 28, 2008 | Cameras
JVC BR-DV600U Mini DV VCR Logo
148 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
