Question about Cuisinart Private Reserve CWC-600 Wine Cooler
Cuisinart wine fridge clicking noise
Clicking sound
Good morning, our wine enthusiast fridge, model 280 06 26 04 is making a drawn out humming noise. Any insight on what to do?
If the sound is from the back of the fridge the there is problem with the compressor or the motor fan. sound from the bottom of the fridge is due to your fridge is off balance. If the sound is from inside the fridge and becomes louder when you open the fridge, then your evaporation motor is probably broken.
Nov 07, 2016 | Wine Enthusiast Refrigerators
I have had my wine fridge for 16 months & it was running all the time and it started making a loud clanking noise from the fan area. I haven't had it that long. What is causing this problem?
I would start by checking to see if anything is touching the fan blades. Believe it or not, mice typically get decapitated by them. Also wires can get in the way. However, About Appliance.com says: "Clicking, banging and knocking: These sounds can come from the compressor telling you there is a problem with it. Normally, it can make a whining or pulsating noise"
May 10, 2015 | Refrigerators
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Even after unplugginf for a day to reset the unit won't cool afte we had a power outage
Try plugging the unit back in, pay close attention after a few seconds, for click near the compressor. If you here this sound then chances are that the relay on the compressor has shorted out. This is an easy and inexpensive repair. If you don't here the click then it may be a control board
Nov 14, 2010 | Cuisinart CWC-1200 Wine Cooler
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Vinotemp Wine Fridge Makes Noise, Doesn't Hold Temperature
Call the place you bought it and check on warranty .
Nov 15, 2017 | VinoTemp (VINO-24GN)
Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Oct 01, 2008 | Cuisinart CWC-1200 Wine Cooler
Cuisinart Private Reserve CWC-600 Wine Cooler Logo
66 people viewed this question
Top Cuisinart Refrigerators Experts
Brian Coughlan
Tom Chichester
Darrell
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
