Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 first camera would just stop shooting with fully charged battery then has been flashing off in readout and wont even turn on. the camera has had little use but lives in humid south fla
    Problem Solver:
  • 9 Answers
Your question is not much clear. When the camera shut off?? eg, after pressing shutter, etc. Did you use original battery?? What is your camera age?
PROBABILITY :
Your camera might be have on/off button problem.
EXPLANATION :
I had experience this with my coolpix 8xxx (could not remember exact model). The problem is with nikon on/off switch and shutter design. After a few years of usage, then the on/off switch with start losen a bit. These will cause autofocus activated without you pressing the shutter yet, and it will shut off without warning.
SOLUTION.
There is no DIY solution for this problem. For temporary, try your luck with pressing the on/off swith a bit harder. But that is for temporary + a bit of luck. Best solution is to send the camera to Nikon Centre.
Posted on Nov 05, 2008
D80 will not turn on...battery fully charged
I would contact Nikon tech support at www.nikon.com. They may be able to give you some suggestions. It appears from what you said that the camera is not seeing the battery and that may indicate that your contacts in the battery compartment are dirty and need cleaning.
Jan 22, 2013 | Nikon D80 Digital Camera
Do you get any numerals in the TOP LCD? Say a flashing ERR?
Or just no power and nothing works?
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
I have a Nikon D80. The flash is not working.
if u r getting green signal of flash charging,then discharging section is defective,sochaque the section replace the parts xenon tube etc or take it to a tech.
Apr 02, 2010 | Nikon D80 Digital Camera with 18-135mm...
My camera wont let me look do anything it turns on and thats it.
If you turn off your flash you might get a picture or two more,The flash consumes probably 3/4 of the battery.I have Sony,HP,Fuji,and Cannon cameras,they walk thru batteries like they're free for the taking.
Jan 17, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Mar 01, 2009 | Nikon D80 Digital Camera with 18-200mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
