Question about Samsung Televison & Video
HCR4351WX/XAC PICTURE IS ALL GREEN AND YELLOW
I have a Samsung floor model TV model number HCP4363WX/XAC I think it's the color aliment but picture looks fuzzy it kinda looks like it 3D how do I fix this issue.
That tv is a rear projection tv. It uses 3 CRT tubes that are Blue, Red, and Green and converges the pictures on top of each other. The convergence chip needs to be replaced. Samsung Akai Projection TV Repair Kit for one or more of the following...
You can order the repair kit from here and it comes with step by step instructions for the repair. I have personally used them before with a lot of success.
Jan 25, 2017 | Samsung Televison & Video
I have a Samsung HLP5663WX/XAC. I have sound but no picture. The lamp light is blinking and I can't turn the power off unless I unplug the tv. Any help would be good.
This kind of symptoms indicated that the DMD module is loading down the control bus and stuck to this process. You have to replaced it part no. BP96-00678A. I saw your board at Ebay.com.
Hope I helped you.
Have a nice day!
Jdvillanueva
Dec 12, 2011 | Samsung DLP HL-P5663W 56" TV
Audio is good, screen is a green/yellow
is a problrma in antenna cable that you check the wiring
Jan 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
YThe colors in my picture have yellow/green color cast.
When you take pictures under certain artificial lighting conditions- such as fluorescent, incandescent, or halogen lighting, the colors in your image may take on a yellow or green cast. You can use HotShots to touch-up the colors; see Chapter 7 for instructions.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Televison & Video Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
