Question about Kenmore Refrigerators
Not starting after being left open all night.
  • 341 Answers
You may have burned out the compressor motor as it was forced to run all night trying to cool the unit with the door open. The compressor motors in home refrigerators are not designed for running continuously. Call 1-800-KENMORE for help.
Posted on Feb 13, 2012
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
My webcam night mode is turn off how can i turn it back on
Face Recognition Usually you'll find the webcam at the top and middle of the laptop screen. One unique feature included with the webcam on newer Toshiba laptops including the Satellite Pro, Portege and Qosmio models is facial recognition. Instead of having to type in a password when you open the laptop, you can set up the computer to recognize your face and automatically load your settings. b> Setup b> To access the face recognition feature on a Toshiba laptop, open the laptop to the registration screen and click the Face Recognition icon. Look at the circle that appears on the screen and align your face so that it fits within the circle, and then click "Next." At the next page, enter your name and password and click "OK." The next time you use the computer, click on your Face Recognition icon from the main screen and look at the webcam so it can recognize your face and load your settings. b> Night Mode b> If you're in a low-light situation you can take advantage of the webcam's Night Mode effect. To turn it on, open the Camera Assistant by clicking the Start button, and then select "All Programs."
Select the "Camera Assistant" folder and then select the "Camera Assistant" software. Once it's open, hover your mouse over the far left hand side of your laptop screen. This will cause a number of webcam icons to appear. Click the "Properties" icon, which looks like a box with a pen over the top left of the box. Click the "Night Mode" check box from the Properties window and then click "OK." b> Other Profiles b> You can also alter other effects and features of the webcam from the Camera Assistant. First open the Camera Assistant by clicking the Start button, and then select "All Programs." Select the "Camera Assistant" folder and then select the "Camera Assistant" software. Then hover your cursor on the far left of the screen until you see the webcam menu appear, and select the "Properties" icon. Then click on an individual "Profile" tab to adjust the white balance, lower or raise the brightness, or correct the colors. As you click on the adjustment, you should see the change reflected in the way the webcam is displaying on your laptop. When you've selected the settings you want, click "OK" from the Profile window.
Feb 01, 2013 | Toshiba Satellite Computers & Internet
Refrigerator was left open all night and it no longer works? What could be wrong
That unit uses a very small compressor. My guess would be, that since it was open all night, the unit tried to run with higher than normal freon pressures. This could cause the compressor to go out on it's protection device, normally called and overload. If you let the unit completely cool off, then try turning it back on, it might work. Repeated trips of the overload could cause the overload to go bad, not necessarily the compressor. It could also cause start components to go bad too. Such as the relay or capacitor. Good Luck and hope this helps
Jun 07, 2009 | Haier HSB03 Compact Refrigerator
Fusible link in 1993 festiva
Had a customers car do this and tested the daylights out of everything to no avail..."non-factory" solution was to replace link with a 30 amp breaker...when problem happened breaker would open, then close several minutes later, returning to normal operation. Can't hurt to try it!!!
May 28, 2009 | 1993 Ford Festiva
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Climate control stopped operating overnight during below freezing
Well last night I went under the hood, opened the fuse panel and removed the "Memory"/Audio fuse, in my car it was yellow and only pulled up, not out, it was a "20". I left it out for a few min, pushed the fuse back in and everything is fine now, just have to reset my clock.
Hope this helps all!
Jan 03, 2009 | 2005 Kia Sorento
2001 Pontiac Bonneville won't start
have you not left any load on overnight?..like park light or left the door partially open and the dome light would be left on?
have the battery recharge and the next night, make sure that no light would be left on the car.
if it would drain out again, have it recharged again, use it and on the night, make sure no light is left on the car, then remove the positive pole on the battery overnight.
the next morning, put the positive cable back and start the car.
if the car would start, then no problem with the battery, if the car would not start, then return the battery because it is defective.
tnx 4 using fixya,
drcool
Oct 20, 2008 | 2001 Pontiac Bonneville
Left refrigerator door open over night, next day it stopped working
sounds like you sucked in a lot of warm air over night freezer still working? just the refrig went out???easiest solution empty unit completly, unplug and leave doors open let al frost melt out 24 hrs later plug back in and you should be find
Feb 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
After my mini fridge was left open over night, it doesnt get cold anymore....
Being left open can let lots of moisture in that can freeze up the air circulation paths. First thing is to leave it off and unplugged for a couple days to melt any hidden ice build up from being open all night. Then start it up like normal and see if it works properly. If not then repost and we'll go from there.
Jan 09, 2007 | Haier HSB03 Compact Refrigerator
Refrigerators Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
