Question about Compaq Presario R3310US (829160642062) PC Notebook
Charger not Charging System.
Hi, I inherited a Compaq Presario R3410US. The only problem it has is that the little pin that is used to connect the charger cord to the motherboard has broken off. It appears that this is directly connected to the motherboard. Do I have to replace the entire motherboard, or is there some service somewhere that can solder it to my motherboard? I still have the original pin that was inside of the charger jack. Any suggestions are appreciated. Thanks in advance.
  • 29 Answers
Im not sure what pin your talking about so, let me give you to answers, If Got a good friend with a steady hand, who's good with computers, and a solder iron?, take it to him, if not, take it to a excellent (and i mean EXCELLENT) computer store, and see if they can take apart your laptop, and solder the peice back on. but, if this is the male connecter, that you actully plug the power adapter into, id it the pin inside the hole, then you'll need a new motherboard
Posted on Aug 12, 2006
Compaq celeron B830 WINDOWS 8 BATTERY NOT CHARGING
It seems a few guys on here are missing the point, if you wish to check to see if you dc socket is faulty you need a good working charger and a multimeter set to DC volts.. Remove your battery and inside the battery compartment there are a series of brass looking contacts some are longer than others, the longer ones 90% of the time represent the Negative ( -V ) or Ground, Connect your black meter lead to one of the longer terminals and continue to probe your red lead on the other smaller terminals and see what reading you get.. if you see a small voltage thats dropping this normally means you are on the pins that connect to the output of the battery and as such capacitors on your main board are discharging (hence the voltage drop). if you see 3.3v on some pins this indicates the charging voltage and shows your dc socket is in fact working fine and that the problem is with your charging circuitry on the main board which is where i am at the moment, trying to find the relavant information to allow me to repair it, LOL hope this helps..
Jan 06, 2013 | HP Compaq Presario Cq58 250Sa 15.6-Inch...
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
My compaq presario c795tu battery is not charging
Unplug the power supply, take a stiff tooth brush and clean the battery terminals in the laptop plus the battery, re-install the battery and plug the charger in, If that fails you need to find out if the charging circuits are putting out the proper voltage before you replace the battery.
Mar 04, 2012 | HP Compaq Presario CQ40-330TU
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Compaq presario C762NR notebook pc I have trouble charging it, the blue light turns on and off. Once I plug it in I need to move the charger around in order to start charging
You either have bad wires or loose connection. Take the prongs on the plugin and bend them both outwards. Use wrench if needed. Bend them just enough so they will stay in the outlet without being loose. This is the most common problem with charging
Jul 19, 2009 | HP Compaq Presario C762NR Notebook
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
Sir i have a problem in my compaq presario cq-60 104tu modle , i have installed xp instead of vista (6 months using vista ultimate) after installation in 3-4 days there is a problem in its charging system,...
Installing Windows XP will have no effect on your charging system. Have the charger and plug socket checked at your local PC store.
Best wishes,
Graemevm
May 01, 2009 | Microsoft Windows XP Professional
Compaq Presario R3310US (829160642062) PC Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
