Question about BMW Vehicle Parts & Accessories
How to change oil sensor on bmw 320ci - BMW Vehicle Parts & Accessories
  • Thomas Perkins
    Thomas Perkins Feb 12, 2012
    The oil pressure switch is located near the oil filter,look at the picture of part and you will see,remove electrical connector,get wrench and remove.
3 Suggested Answers
messstat
  • 365 Answers
SOURCE: Reset ''Service Oil'' sensor on a 1985 BMW 325E off dash console
Call your local BMW dealer and ask them...should be free!
Good Luck
Posted on Jun 14, 2009
  • 92 Answers
SOURCE: oil leak
the dealer parts dept usually has the best exploded diagrams
Posted on Sep 30, 2009
BMW 320ci. Runs perfectly 1st start can run for 1000's miles no issues. 2nd start car takes longer to start,delayed throttle response,lacks power climbing hills prone to cutting out as revs drop.
sounds like crank sensor or cam shaft sensor. Internal resistance due to heat, hence why you can start and run car in morning, ie cold. When the heat build errors start. Get codes read first but I would suspect these 2 sensors. Yo can also get fault new parts, so you might be one the right track.
Dec 22, 2016 | BMW 320Ci Cars & Trucks
Where is the fuse panel on BMW 320ci
In the matter of fuses and fuse box locations there are geographic differences and even official repair manuals are vague about such things and so the best authority is the vehicle handbook.
Many modern vehicles have more than one fusebox and some also use fusible links attached to the battery.
Feb 12, 2015 | BMW Cars & Trucks
BMW 2003 325. When I derive a car for about 30 min
Is this the oil pressure sensor you changed?
Aug 31, 2013 | 2003 BMW 325
2001 3 Series: automatic warning lamp came on on my 320ci...
Which warning light? Check engine? Traction? Transmission? Can you give me a more detailed description? With a check engine light Autozone will check it for free and give you the code that caused the light to come on. With the code you can troubleshoot and repair.
May 17, 2010 | 2001 BMW 3 Series
Airbag warning light is on in my bmw 318i 2004 what is wrong is it going to cost a lot of money to fix
prob the passenger occupancy seat sensor mat, common fault on the e46, happened to my 320ci o4 plate, around 200 pound to fix, but could go wrong again.
Apr 10, 2010 | 2004 BMW 3 Series
Oil servicing?
oil changes are scheduled by mileage and or days. it appears you have reached the time in which your bmw is due for an oil change
Dec 04, 2009 | 2002 BMW 3 Series
Oil leak
Sep 30, 2009 | 2003 BMW 325
Hi i have a bmw 320ci 2001 and sometimes when i get in and turn ignition on it wont start. i've found the only way to make it start is by pressing the lock and unlock button a few times. hope you can help....
Have you ever changed the battery in the key fob? Next time you go to start it unlock it by using the key in the drivers door lock turn to the unlock position and hold there your windows will lower and sunroof will open. Get in and start car if you do not have to lock/unlock to start change the fob battery if you do need the lock/unlock move your chip in your key is bad
Jul 08, 2009 | 2001 BMW 330
Vehicle Parts & Accessories Logo
73 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
