Question about HP Office Equipment & Supplies
I took Paper from the front now the it keeps saying carrage jam(hp Photosmart C7180 all in one)
    Novelist:
  • 180 Answers
Step one: Print a self-test report Follow the steps below:
  1. Press the Power button to turn on the product.
  2. Press Setup on the product control panel.
  3. Press the right arrow button until Print Report displays on the control panel display, and then press OK . The self-test report prints.
  4. Analyze the results:
    • If the product prints a self-test report, there is no need to follow the remaining steps, because the error message might be false. Try to print something from the computer.
    • If the product does not print a self-test report, proceed to the next step.
Step two: Clear the paper path Follow the steps below to clear the product of any jammed paper.
  1. Make sure the product is on, and then disconnect the power cord and the USB or Ethernet cable from the back of the product. Do not reconnect them until instructed to later. NOTE: Make sure the product is on before disconnecting the power cord. Failure to disconnect the power cord from the product can cause damage when removing jammed paper.
  2. Open the top access door by lifting from the front center of the product until the door locks into place. Figure 1: Opening the top access door I took Paper from the - c00786115.gif
  3. Note where the carriage is stuck and look for jammed paper. NOTE: The carriage is the device that contains the printhead and moves left to right during printing. A paper jam can cause the error message and the carriage stall. Paper might be jammed in different locations and might cause the carriage to be stuck in the middle of the product or on the right or left side.
  4. Remove any jammed paper. NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the product. Follow these instructions if the carriage is stuck on the right side or the left side of the product:
    1. Check for and remove any paper or object that might be restricting the carriage.
    2. Manually move the carriage to the opposite side of the product.
    3. Check the paper path all the way to the side on which the carriage was initially stuck. Remove any paper along the path.
    Follow these instructions if the carriage is stuck in the middle of the product:
    2. Manually move the carriage all the way to the left side of the product.
    3. Check the paper path all the way to the right side and remove any paper along the path.
    4. Manually move the carriage all the way to the right side of the product.
    5. Check the paper path all the way to the left side and remove any paper along the path.
  5. Remove the rear access door or duplexer (if installed) from the back of the product. To remove, press in the tabs on the left and right side, and pull it away from the product.
  6. Check for and remove any paper still in the product.
  7. Replace the rear access door or duplexer, and then close the top access door.
  8. Reconnect only the power cord (do not connect the USB or Ethernet cables at this time). If the product does not automatically turn on, press the Power button. NOTE: The product might go through a warm-up period of up to two minutes. Lights might flash and the carriage might move. Wait until the warm-up period is complete before going to the next step.
  9. Check the power light.
    • If the power light is on, reconnect the USB or Ethernet cable to the product, and then print a self-test report as done in Step one.
    • If the power light is blinking or not on and the carriage is still stuck, reconnect the USB or Ethernet cable to the product, and then proceed to Step three.
Step three: Plug the All-in-One directly into a wall outlet Use these steps to make sure the product is properly connected to a suitable power source.
  1. Make sure the computer and the product have a three-prong power plug.
  2. Remove the product power cord from any power strips or surge suppressors, and then plug it directly into a grounded wall outlet.
  3. Try the print job again to see if this step resolved the issue. NOTE: If the product prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor might not be allowing sufficient voltage to reach the product. If this did not resolve the issue, proceed to the next step.
Step four: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Oct 24, 2008
Hp photosmart printer keeps saying paper jam
Use a flashlight to examine as much as possible of the papaer path. There may be bits of paper or paper debris lodged in some obscure corner
Sep 29, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
My printer keep saying clear carriage jam but there isnt anything that is still jamed. How do i fix this problem . I can't get it to work now
The printer is telling you that something is jamming the printer carriage, or the rod, that the print cartridges ride on. Open your printer up to where you would install your print cartridges, either front load or top load. See if you can find anything in the path of its movement.
Remove it, and try printing again.
Look for paper that may have jammed recently in the printer.
If that doesn't fis it, try moving the printer cartridge holder manually and then try to clear the message again.
Hope this helps.....
Please rate my response!!
Jan 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
My HP C7100 says that there is a paper jam when theres not.
if you said that you have cleared it of any paper then its time to have your printer check by a printer technician, a small piece of paper still stuck in there will cause the printer to sya these, check it again maybe you missed a spot, if you are sure you cleared it up real good then take your printer to a repair man to avoid any furthere more damage to the printer
Nov 20, 2009 | HP Photosmart C7180 All-In-One InkJet...
Paper jams in HP Photosmart C7180 All-in-one
Underneath paper tray spring had broken and the drawer wasnt going right into position, needed to move lugs underneath which allowed tray into proper position and now all is well!!
Apr 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
427 people viewed this question
Seeker5211
Seeker5211
