Question about As Seen On TV Sewing Machines
Dressmaker 11 model 1100EF
Thread is getting tangled and I cannot get bobbin thread to ix with thread to make stitch. Also the only way I can get it to stop is to turn machine off??
jpack76645
  • 23 Answers
SOURCE: needle will not pick up the bobbin thread, gets
Oh boy! I've worked on industrial sewing machines for over 30 years, but the home sewing machines are like comparing cadillacs to mopeds. No offense, but if you want performance out of a machine try an industrial. It will shock you with the difference. Be glad to help you find the right one.
Anyway, the problem you are having is quite common. First, make sure it is threaded right especially the moving spring on the needle thread tension) and the needle is new. This generally covers 75% of the problem. Make sure the bobbin thread is threaded correctly.
If you are still having the problem remove the bobbin/bobbin case and observe the needle/hook point relationship as you turn the handwheel. The hook point should pass behind the needle at the scarf of the needle (indention just above eye of needle) If it is not so the needle bar may have moved up on you. Did the machine get jammed?
I'm not sure about the rod you're talking about but lets try this first.
Posted on May 18, 2009
mark24354
  • 776 Answers
SOURCE: bobbin thread and top thread
Option 1)
The bobbin may not be installed exactly in the right way (a little askew).
Option 2)
The Tension needs to be adjusted
Option 3)
Your needle is bent or dull
Option 4)
One thread does not work well with the other. The threads must be able to slide and tighten, too much friction for one thread can cause tangles.
Let me know if any of those are pointing us in the right direction. i can give more advise as needed. Also, check youtube.com to learn how to set the tension on your machine (most are similar, the knob is just in a different place on each machine).
Try:
http://www.youtube.com/watch?v=es24cH-uRQU
The tension contolls the feed rate for the bottom (bobbin thread). The top thread is mostly controlled by the stitch length knob. Play with both a bit. Bottom should come out when pulled gently but give some resistance. Good luck.
Posted on May 22, 2011
  • 1456 Answers
SOURCE: bobbin thread is tangling around bobbin carriage
Hello
This is Really not that big a problem. Simply pull out the bobbin thread with a long lead, put the assembled bobbin into the sewingmachine and take that long thread and close it between the sliding door and the machine itself to hold it temporarly.
Most sewing machine problems are caused by the usasge of wrong thread type. Make sure you have a thread that is for a sewing machine use, that is, good strong stuff, not hand needle basting thread as that will cause much problems.
Often the bobbin is thought to be the problem, those things are almost never the problem. A source of problems also is the usage of wrong or improperly machined flat on the needle itself. Be sure to buy a quality needle as that flat on there, if machined not deep enough will not allow the bobbin to pick up the thread, wind it around and form the stitch.
Posted on Jul 12, 2011
SOURCE: E6. Motor locked up because the thread is
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Posted on Aug 03, 2011
  • 79 Answers
SOURCE: I am using my new
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
Posted on Sep 23, 2011
How do I reassemble drop-in bobbin case for Brothers XL 2600 free arm?
Do you have some pictures of the area involved. I know how to put these things back but I can't think how to explain it to you.. pics might help me show you.
Brother has an outstanding service department, and if you don't have a manual, they should have one. Should have a pic of how it goes together.
Aug 02, 2014 | Brother XL-2600
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
Worked great until the needle broke and now the bobbin thread bunches up
Hello
Clean out the bobbin area if there are any thread tangles there.
If the bobbin does not fit snugly into the bobbin case, then get new bobbins. You need class A or 15 and they do not cost very much. Make sure they are plastic and not metal.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
There should be a tension setting for your bobbin thread, as well as your top thread. It sounds to me like your bobbin tension setting is not in sync with your top thread.
most common solution to this is to remove the top thread completely from machine and re thread it with the presser foot UP not down. This will allow the top thread to engage properly in the top tension disc
Aug 10, 2011 | Brother LS-2125 Mechanical Sewing Machine
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Needle will not pick up the bobbin thread, gets tangled when stitching. My user manual shows a little clip/rod to hold bobbin thread in place, my bobbin holder does not have one. It is brand new,...
May 18, 2009 | Euro-Pro Dressmaker 998B
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
42 people viewed this question
Top As Seen On TV Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
