Question about Sewing Machines
This is the first time I have lowered the feeddogs on my machine and now I can't get them to go back up. Help please!
I have moved the slider bar back to the up position but nothing happens.
    Novelist:
  • Sewing Machines Expert
  • 166 Answers
When you release the feed-dog drop button, you need to rotate the handwheel a couple of times for the feed-dogs to come back up and engage properly, they wont just come up on their own.
Posted on Feb 14, 2012
5 Suggested Answers
  • 149 Answers
SOURCE: feeddog isn't working
your stitch length may be set to zero
Posted on Apr 09, 2010
RichSew
  • 194 Answers
SOURCE: I have a Brother CS6000i & the feeddogs are
Be sure and let the machine make a couple of sitches to see if the feed will come up. Flipping the switch does not raise the feed.
Posted on Apr 14, 2010
  • 1788 Answers
SOURCE: When I lower the presser foot to sew, there is no
Check your book and read what the tension should be, and make sure that the feed dogs are up.
Posted on Sep 12, 2010
  • 1456 Answers
SOURCE: My fabric wasn't moving so
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Posted on Jul 12, 2011
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
Kenmoresewingmachine won't feed material
You may have accidentally lowered the feed dogs. Look for a toggle switch that will raise them up again. Mine is to the left of my power button.
Jul 22, 2014 | Sewing Machines
Feeddog won't move with pressure foot down. I have a Baby Lock BL4-428. I haven't used it in a while. I cleaned it up and oiled it. The feeddog moves when the pressure foot is up but as so
it sound like the feed dog & the presser foot need to be adjusted
so they work togeather,,it's very possible they need to be timed
a sewing machine repair shop can tell you for sure
Sep 05, 2012 | Baby Lock Sewing Machines
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
Frozen feed gears singer sewing
the machine needs to be checked when the feeddogs don't move
but first check to see if the feeddogs are in the up position & if the
feeddogs are up, then the machine needs to be checked
Apr 28, 2012 | Singer Sewing Machines
Dog feeds not working
check the feeddog to see if there in the up position, you'll be able to see & feel the feeddog teeth with your fingers,, but if you can't feel them the check the feeddog knob or lever.
if the lever is in the up position & you can't move the lever or if you can move the lever up or down & the feeddogs don't move there position
then it's possible that there's something wrong with them & the machine will have to be serviced
Feb 07, 2012 | Janome Sewing Machines
Feeddog isn't working
Apr 09, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Size of stitch
Sounds like malfunction with the feeddogs or stitch length balance. Without thread or fabric, turn the handwheel and watch the feeddogs (the toothy looking things under the presser foot which moves the fabric as you sew). The amount of distance they move with each revolution of the handwheel determines the stitch length. Watch to see whether they move from front to back. It may be that they are worn out or that they are just too low to adequately move the fabric as you sew. Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Jun 11, 2009 | Husqvarna Viking 1
Fabric stuck when sewing
Several things could be happening. It may be the hook/needle timing. Or it could be the feeddogs are not moving (that's the toothy looking part under the presser foot that moves the fabric). Recommend removing thread and bobbin (needle and presser foot). Slowly move the handwheel and put your finger on top of the feeddogs to determine if they are moving back and forth and are high enough to move the fabric. Check to make sure you had not manually lowered the feed dogs. You may need to take it to an authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Nov 21, 2008 | Husqvarna Viking 1
Husqvarna Viking Designer I (feed dogs will not lower)
Its likely this machines feedogs have either never been lowered or not lowered for a long time. Thus the old oil has hardend and is causing the mechanism to freeze up. A tech would take the bottom cover off, follow the connections from the lowering knob, button or switch to the feeddogs and putting a bit of oil or penetrant on each moving connection. Don't force anything, gently tap where you beleive its sticking and turn, push or flip the switch, knob or button slowly bit by bit, back and forth until they drop. They will work loose then make sure they get a bit of oil again. Hope this helps. Good luck.
Jul 13, 2008 | Husqvarna Designer I
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
